Question: 2nd order ODE with complex coefficient
Hi
Assume a linear second order ode with constant coefficients as follows:
M*u''+C*u'+K*u=0
where the symbol (') denotes derivative with respect to time and M, C and K are positive real constants.
The initial conditions are u(0)=u0 and u'(0)=u'0.
Substituting u=exp(a*t) in the ODE to calculate characteristic equation, one has
M*a^2+C*a+K=0  ---> If 0<C<2sqrt(M*K) then u=exp(-C/(2M)*t)*(c1*sin(w*t)+c2*cos(W*t))
in which c1 and c2 can be obtained from initial conditions and W=sqrt(C^2-4*M*K)/2M.
For the case that C is imaginary number, assuming C=i*c yields
{a1,a2} ={ -(c/(2M) +sqrt(c^2+4*M*K)/2M)*i,(-c/(2M) +sqrt(c^2+4*M*K)/2M)*i }
where i is one of the square roots of -1.
Is it true to write u=c1*(sin(a1*t)+cos(a1*t))+c2*(sin(a2*t)+cos(a2*t)) ?
I solve two examples by Maple,
dsolve({diff(u(t), t, t)+0.1*(diff(u(t), t))+2*u(t)} union {u(0) = 1, (D(u))(0) =0.1});
dsolve({diff(u(t), t, t)+0.1*I*(diff(u(t), t))+2*u(t)} union {u(0) = 1, (D(u))(0) = 0.1});
Second example gives complex answer. Is it possible to get trigonometric answer with real constants c1 and c2?
