Question: Plot from the origin
Good morning, I'm trying to solve this very simple problem : plot a graph starting from the origin. The problem is that the x_axis is located at the lower value of my function, but i want it to go through the point (0,0). Let's see this example:
plot(piecewise( x<5, 100, x>5,200), x=0..10); As you can se the X-axis passes through y=100.
Now with this option I obtain:
plot(piecewise( x<5, 100, x>5,200), x=0..10, y=0..200);
The problem is taht I need to specify the upper bound of the range for each function (200). Is there an automatic way? Any help is appreciated.
