Question: How to export the output of a maple program to excel sheet?
I have a maple code that has two output blocks giving a large number of numerical values for my experiment. I need these values to compare the output in both the code blocks and also to draw several figures using the data. On a single run of the program, a large number of values are obtained and then I manually copy them to excel sheet for further analysis. It takes a lot of my time to copy and paste the results on each run. I want to export the outputs of both the code blocks to a excel sheet. Any suggestion on this problem will be helpful to me. Thanks.
The link to my code is  maple-excel.mw.
I want the output in this format Book1.xlsx
