Question: How do I visualize volume under a surface over a non-rectangular region?
I use the plots:-shadebetween( ) command quite a bit to visualize volume under a surface over a planar rectangular region. Is there a way, using this same command, to see said volume over a non-rectangular region? For example, the region bounded above by z = x^2 + y^2, having a triangle base 0<=x<=1, 0<=y<=x. If this command does not allow for this, is there some other solution?
Thanks!
