Question: Issues with pdsolve (2)
There seems to be an issue with pdsolve, which is similar to https://mapleprimes.com/questions/222498-Issues-With-Pdsolve.
pdsolve([diff(u(x, t), t) = diff(u(x, t), x, x), u(x, 0) = 1, u(0, t) = 0, u(2, t) = 0]); # works
pdsolve([diff(u(t, x), t) = diff(u(t, x), x, x), u(0, x) = 1, u(t, 0) = 0, u(t, 2) = 0]); # swapped arguments, works
pdsolve([diff(u(x, t), t) = diff(u(x, t), x, x), u(x, 0) = 1, u(-1, t) = 0, u(1, t) = 0]); # translate by -1, works
pdsolve([diff(u(t, x), t) = diff(u(t, x), x, x), u(0, x) = 1, u(t, -1) = 0, u(t, 1) = 0]); # swapped arguments and translate by -1, doesn't work
The solution for the last example doesn't incorporate the initial condition correctly, while it is the same as the third example (except for swapped arguments). Not sure if this is still a problem in Maple 2019, though.
