Question: Match parameter name of a function
I'm trying to create an iterator function
Iter := proc(ff, n)
    local i,f;
    if n = 0 then return (x->x); end;
    f := x->ff:
    f := apply(unapply(ff))(x);
    for i from 1 to n-1 do
        f := ff(f);
    end;
    return unapply(f,x);
end:
This seems to work except that it converts the independent variable to x, which can cause problems.
That is, if I pass something like n->sin(n) then it will output something like x->sin(sin(x))...
Of course, I do explicitly use x but it is because I don't know how to get the input's independent variable.
Ideally I'd like to be able to work on multiple arguments and iterate over the first, by default.
e.g., f#2(x,y,z) = f(f(x,y,z),y,z)
Ultimately the proc above doesn't work well as I want to be able to use it in all contexts(I could pass the value to Iter but I'd rather use function notation.
