Question: Kind help if anyone to convert the c++ code to maple code
#include<iostream>
#include<vector>
#include<cmath>
#define NODE 8
using namespace std;
int graph[NODE][NODE] = {
   {0,1,1,0,0,0,0,0},
   {1,0,1,1,1,0,0,0},
   {1,1,0,1,0,1,0,0},
   {0,1,1,0,0,0,0,0},
   {0,1,0,0,0,1,1,1},
   {0,0,1,0,1,0,1,1},
   {0,0,0,0,1,1,0,0},
   {0,0,0,0,1,1,0,0}
int tempGraph[NODE][NODE];
int findStartVert() {
   for(int i = 0; i<NODE; i++) {
      int deg = 0;
      for(int j = 0; j<NODE; j++) {
         if(tempGraph[i][j])
            deg++; //increase degree, when connected edge found
      if(deg % 2 != 0) //when degree of vertices are odd
      return i; //i is node with odd degree
   return 0; //when all vertices have even degree, start from 0
int dfs(int prev, int start, bool visited[]){
   int count = 1;
   visited[start] = true;
   for(int u = 0; u<NODE; u++){
      if(prev != u){
         if(!visited[u]){
            if(tempGraph[start][u]){
               count += dfs(start, u, visited);
   return count;
bool isBridge(int u, int v) {
   int deg = 0;
      if(tempGraph[v][i])
   deg++;
   if(deg>1) {
      return false; //the edge is not forming bridge
   return true; //edge forming a bridge
int edgeCount() {
   int count = 0;
      for(int j = i; j<NODE; j++)
         if(tempGraph[i][j])
   count++;
   return count;
void fleuryAlgorithm(int start) {
   static int edge = edgeCount();
   static int v_count = NODE;
   for(int v = 0; v<NODE; v++) {
      if(tempGraph[start][v]) {
         bool visited[NODE] = {false};
         if(isBridge(start, v)){
            v_count--;
         int cnt = dfs(start, v, visited);
         if(abs(v_count-cnt) <= 2){
            cout << start << "--" << v << " ";
            if(isBridge(v, start)){
               v_count--;
            tempGraph[start][v] = tempGraph[v][start] = 0; //remove edge from graph
            edge--;
            fleuryAlgorithm(v);
int main() {
   for(int i = 0; i<NODE; i++) //copy main graph to tempGraph
      tempGraph[i][j] = graph[i][j];
   cout << "Euler Path Or Circuit: ";
   fleuryAlgorithm(findStartVert());
Kind help
