Question: How to set axis values in plot command
The plot command below results in the following graph:
However, I want the x-axis to go from 0..24 and the y-axis from 0..100. I can adjust the shafts temporarily via Axes-Properties so that I get the following plot:
However, as soon as I recalculate the plot command, I get back the original plot. Is there any parameter in the plot command where I can set x-min, x-max, ymin, ymax?
Regards,
Christer
