Question: Matlab code generation ... ???
When I want to generate matlab code of the following symbolic expression I got very strange result:
with(CodeGeneration);
Matlab(Sum(a(i), i = 1 .. N));
Warning, the function names {Sum, a} are not recognized in the target language
Warning, precedence for Range unspecified
Warning, cannot translate range
cg = Sum(a(i), i == (1..N));
Problem:Sum(a(i), i == (1..N));
This command has wrong matlab syntax!!!
Right matlab code should look like:
cg = sum(a);
Where can I found compete list of supported matlab built-in function? Is there any possibility how to get proper matlab code?
Is there any way how to convert more complex symbilic expressions to the Matlab???
