Question: How Do I make code run once ?
Dear Forum,
I want to make a Document where some values are initialised and left alone afterwards.
The startup-code seems to be the solution. The manual says, it is executed, when the document is reloaded.
But if i execute the document with "!!!" the startup-code is executed too.
How can I avoid this ?
Is there a good way to write "run once" code ?
Thank you very much
Klaus
startup code is  :
init:=false;
After reloading, this should be false  init = trueNULL
the startup code should be executed after reloading but is executed when the code is executed with !!! . init is set to false again
If the code is executed stepwise , ! by ! , it behaves as expected.
if not init then x := 3; y := 4; init := true end if
2*x = 8NULL
x := 4
4
2*x = 8NULL
Download doesnotrunonce.mw
