Question: Write output of for loop to .txt file with additional text
I have the following code. I want to do the modify it so that:
1. The outputs of each for loop are merged in such a way that the outputs from the first loop (Es) that are also outputs of the second loop (Fs) are removed from the outputs of (Es).
2. The resulting outputs G= .... are saved to a text file, one to each line.
3. In between each output, I want to add 5 lines of text and a blank line, say
text1 text2 text3
text2 text2 text3
text3 text3 text3
text4 text4 text4
text5 text5 text5
(blank line)
so that in the text file, the format is (e.g.)
G={{1,2}};
text1 text2 text3
text2 text2 text3
text3 text3 text3
text4 text4 text4
text5 text5 text5
(blank line)
G={{1,2},{1,3}};
text1 text2 text3
text2 text2 text3
text3 text3 text3
text4 text4 text4
text5 text5 text5
(blank line)
etc.
What is the easiest way to accomplish this?
with(GraphTheory):
 n:= 4:
  L:= NonIsomorphicGraphs
      ( n,
        output=iterator,
        outputform=graph):
  Es:= Array
       ( [ seq
           (  Edges( L() ),
              j=1..NonIsomorphicGraphs
                   ( n,
                     output=count
  M:= NonIsomorphicGraphs
      ( n-1,
        output=iterator,
        outputform=graph):
  Fs:= Array
       ( [ seq
           (  Edges( M() ),
                   ( n-1,
                     output=count
numelems(Es):
for i from 1 to numelems(Es) do G:=Es[i]:  od;
numelems(Fs):
for i to numelems(Fs) do G := Fs[i]; od;
