Question: How to change output of mtaylor command?
I want to change the output of the mtaylor command, eg for 3 series terms
ftaylor:=mtaylor(f(x,y),[x,y],3);
gives
ftaylor := f(0,0)+D[1](f)(0,0)*x+D[2](f)(0,0)*y+1/2*D[1,1](f)(0,0)*x^2+D[1,2](f)(0,0)*x*y+1/2*D[2,2](f)(0,0)*y^2;
I want the output as ftaylor := g(x,y) + D[1](g(x,y)) *x + D[2](g(x,y))*y + .... etc for all the terms in ftaylor.
Later on g(x,y) can be defined and terms like D[1](g(x,y)) evaluated.
I tried
subs(f(0,0)=g(x,y),ftaylor);
but it doesn't work. Using eval doesn't work either.
Is there a way to do this?
Thank you in advance.
