Question: Does Maple really add a lib directory inside the current working directory to libname?
There is a document on the Maple website entitled "Writing Packages". It contains the following snippet when talking about libname
Note: Maple automatically adds lib subdirectories of directories in HOMEDIR/maple/toolbox as well as your current directory to the predefined variable libname. Therefore, modifying the .mapleinit or maple.ini file is only necessary if you want to designate a directory as the default location in which the savelib command will save your library files.
Is this snippet accurate?
If we create a directory called test and create a directory inside called lib and in it a repository called myRepo.mla, and in Maple the current working directory is test, will test/lib/myRepo.mla be found by libname?
It doesn't seem to be the case.
