Question: Create excel file with sheets of independent variables subsets
Given a excel sheet with data for regression as input column Y will be a dependent variable
Say a maximum of 120 independent variables are their
A function that takes excel as input with headers as in the excel file
Do pick all possible subsets of maximum size 5 that is sizes 2,3,4,5 only
Pick each and eleminate not to store them all together as otherwise storage will be a problem if more data
Copy only those subsets of independent variables to seperate seperate sheet
Only those subsets
where the variables are independent pairwise between them
Step 2 function
Then need to run a multiple linear regression on these subsets like training and test
And choose the best models I each of cases of number of variable
That is best with 2 variables
Again with 3 variables
Similarly 4 and 5
Atleast if possible upto 2 to 3 variables it will be good kind help with your guidance and what is possible
If you are not able give the program of train test regression with charts no issues
Kind help with atleast storing the independent pairwise subsets of size 2 and 3 into seperate sheets in a Excel file atleast
I will do the regression at my end
