Question: How does one simply extract the exponent of one factor of an integer?
I want to know the exponent of one particular factor of an integer. For example:
k:=24;
ifactor(k) = (2)^3(3)
and I want to write a module to extract the exponent of (3) for any arbitrary k.
I can't select for the presence of 3 because it will pick up the factor (2)^3 and then it gets complicated to decide that I don't want this factor anyway.
If I somehow manage to select the factor (3) using "op" and scanning through each factor in turn, then substitute 3=x, it turns out that degree(%,x) doesn't work because the factor x is enclosed in brackets; similarly trying
log(%,3) fails for the same reason.
There has to be a simple way, but I just don't see it.
Any suggestions are appreciated.
