Question: convert~ in nested lists
Is it correct that element wise operators just work on the first element, and not in nested elements?
Do I need to manually go through the nested lists, or are there any other tricks to simplify this operation?
fasteners := [Vector(2, {(1) = -25.0*Units:-Unit(mm), (2) = 0.}), Vector(2, {(1) = 25.0*Units:-Unit(mm), (2) = 0.})]
[Vector[column](%id = 36893490765018711092), Vector[column](%id = 36893490765018711212)]
`~`[convert](fasteners, unit_free)
[Vector[column](%id = 36893490764941411500), Vector[column](%id = 36893490764941411620)]
x := Vector(2, {(1) = -25.0*Units:-Unit(mm), (2) = 0.})
Vector[column](%id = 36893490765009212828)
`~`[convert](x, unit_free)
Vector[column](%id = 36893490764944766844)
Download elementwise.mw
