Question: effect of evala on expression when using integrate command
Could someone help me understand why Maple's int hangs when using int on an integrand if evala is not first applied to the integrand?
When I mean hangs, I mean really hangs. I have timelimit and maple server.exe runs at high CPU for hrs. When adding evala(), it completes instantly and returns unevaluated integral (which is just fine as I did not expect this to be evaluated) but it does not hang which is the main point.
Is this considered normal behaviour or a bug?  Should then one always add evala() on the integrand before using int?  As I get many hangs on int (even when using timelimit). I am not familiar with evala command as I have never had to use it before, but by chance I tried it and noticed this.
V 2023 on windows 10. Worksheet attached.
186932
expr:=-1/3*2^(2/3)/((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)*((-1/2*a^2*p-1/2*p^2*a+1/2*p*((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)*a-3)*(-p^2*(-((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)+a+p))^(2/3)+2^(2/3)*p*(-(a+3/2*p)*p*((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)+a^2*p+5/2*p^2*a+3/2*p^3+3))/(-((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)+a+p)/(-1/2*2^(2/3)*(-p^2*(-((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)+a+p))^(2/3)+p*(p*(-p^2*(-((a^2*p+2*a*p^2+p^3+4)/p)^(1/2)+a+p))^(1/3)+2^(1/3)))/p^2:
try
    anti := timelimit(30,int(evala(expr),p));
catch:
    print("timed out OK");
end try:
print("done");
"done"
try
    anti := timelimit(30,int(expr,p));
catch:
    print("timed out");
end try;
print("done");
The second case above just hangs. Make sure to save all your work. I found I have to terminate all of Maple sometimes as killing server.exe seems to make the frontend hangs and not respond, ending up losing work in other worksheets which I did not save.
Download int_hangs_june_2_2023.mw
