Question: Surface btw spacecurves in 3d...
Anyone knows how to plot a surface btw 2 spacecurves in 3d? For example a flat curve x^2+y^2=1 which maybe a upper half of above circle for y=0 to 1 and a spacecurve which is a function for example 2+x^2*y. So second curve should be above the first and limit a surface From the top.
Can't find a solution in help and parametric curves does not solve a problem.
In fact it would be enough to have a vertical surface starting on a xy plane and limited by Givenchy function. As it is in line integral calculations.
Regards
Marcin
