Question: A question about RandomVariable
The automatic transformation below is a rule in Maple
a := 3:
b := a^2
                               9
that we can prevent using single quotes for instance.
When a is a random variables this becomes
a := Statistics:-RandomVariable(Uniform(0, 1));
                               _R
b := a^2
                                2
                              _R
# Thus, for instance
Statistics:-Mean(b);
Of course you do know that b is defined as a^2, but if you present this to a student it will be puzzled by the output of b containing _R and not a. Of course you can explain it why this happens, but if b has a more complex expression inoking several random variables, it becomes almost impossible to understand what its display means as it contains only names like _R, _R0, ...
To avoid this difficulty a possibility is to reverse the order of the operations this way
a := 'a':
b := a^2;
                                2
                               a
                              _R
# And then
But this become quite tricky in some situations, for instance
b := a^2 - Mean(a)^2
                          2          2
                         a  - Mean(a)
a := Statistics:-RandomVariable(Uniform(0, 1)):
# The expected result can be got this way
eval(b, Mean = Statistics:-Mean):
Statistics:-Mean(%);
Or, if you upload the Statistics package
with(Statistics):
b := a^2 - ':-Mean'(a)^2
                          2          2
                         a  - Mean(a)
a := RandomVariable(Uniform(0, 1)):
eval(b, ':-Mean' = Mean):
Mean(%);
As we preserved a comprehensible expression for b in the last two examples, this come at the expense of a more complex calculation of the final result.
My goal is the quite simple:  I would like to preserve as long as possible the original names of the random variables (a in the examples above), and get the desired result without never make their "aliases" _R, _R0, _R1, .... appear in intermediate outputs.
The strategy I use is sketched in the file  Manipulation_of_random_variables.mw
Do you have another idea to achieve this goal?
In fact this question could be also stated "Given a random variable _R, could it be possible to recover the name it has been assigned to. I thought to something like this:
b := Statistics:-RandomVariable(Uniform(0, 1));
c := 1:
d := [$1..3]:
                               _R
                              _R0
# This seems correct
FromNames2RV := [anames(RandomVariable)] =~ eval([anames(RandomVariable)]);
                       [b = _R0, a = _R]
# Unfortunately further use of FromNames2RV evaluates its left hand sides
FromNames2RV
                      [_R0 = _R0, _R = _R]
TIA
