Question: How to update document using slider?
Hi Math People,
I can't find an answer if it is possible to insert slider or any other component into document, adjust its value by sliding it and execute all following calculations in the document below the slider, those which depends on the value of slider parameter?
I know this is possible in graphs, or explore command, but could it be simply setting some value let's say "a". Lets set its value by slider and when slider is set, code should automatically update document? This part of code of slider "Action When Value changes"
Or am I expecting too much?
Best regards
Marcin
