Question: How can I extract the entries in a 2-column matrix solution and arrange themin separate ordered pairs?
Hello all.
I am using a k-means cluster routine to partition a set of points into a fixed number of clusters.
The solution assigns points belong to clusters, and this is given in matrix-form. The attached file gives an example of a simple problem that is concerns two clusters (matrices). The entries of each cluster / matrix represent the coordinates of the points in the plane.
I am looking to ..
1. Isolate and label each cluster solution (there may be up to 10), and
2. For each matrix / cluster, arrange the entries into separate ordered pairs.
For example, in this instance, I wish to obtain the following form ..
A: = [[-6.08, 52.99], [-7.26, 55.29], [-6.24, 53.29]]
B: = [[-9.72, 51.46], ... , [-9.81, 53.76]]
I have made several attempts to solve for this, but I simply cannot get the solution to output this form.
Any advise / help you can give will be gratefully received.
Thanks for reading!
Download MaplePrimes_May_31.mw
