Question: Eclipse & Example test.java
Dear all,
I try to run the test.java example but still fails with the error:
Error loading libraries: java.lang.UnsatisfiedLinkError: no jopenmaple in java.library.path: /Library/Frameworks/Maple.framework/Versions/2024/java:/Library/Frameworks/Maple.framework/Versions/2024/java:/Library/Frameworks/Maple.framework/Versions/2024/java
the file jopenmaple.jar is located in
the maple part of my .bash_profile :
# set Maple Home
export MAPLEDIR="/Library/Frameworks/Maple.framework/Versions/2024"
export DYLD_LIBRARY_PATH="$DYLD_LIBRARY_PATH:<BINDIR>"
export MAPLE="<MAPLEDIR>"
export DYLD_LIBRARY_PATH="/Library/Frameworks/Maple.framework/Versions/2024/bin.APPLE_ARM64_MACOS"
export CLASSPATH="/Library/Frameworks/Maple.framework/Versions/2024/JAVA"
The eclipse part:
JDK 22 and Compiler 22
Classpath Variables in Eclipse Java Build Path Settings:
DYLD_LIBRARY_PATH /Library/Frameworks/Maple.framework/Versions/2024/bin.APPLE_ARM64_MACOS
JAVAC /Library/Frameworks/Maple.framework/Versions/2024/java/Maple.jar
MAPLEDIR /Library/Frameworks/Maple.framework/Versions/2024
So I don't know what to do.
