Question: What happened to my question about modifying Maple created procedures?
I have just posted a question about whether it is possible to modify a procedure once the procedure is created.
It disappeared.
I either want to add an option or change the body of the procedure by replacing functions.
The procedure is generated by Maple commands so I cannot do the changes as if I would do it normally when entering by hand.
Is adding an option or changing the body possible?
I can extract the operands by doing op(eval(procname)). But I can neither extract the body nor assemble everything together.
I will delete this message in case the other message reappears.
