Question: relative paths does not seem to work.
Relative path does not seems to work on Linux.
 e.g. consider the read command
 `read  "/home/harpo/skits/slapstick/boguscalculus.mw"
At the moment I have to enter the full path above as stated to be able to read in "boguscalculus.mw"
This highly unfortunte, as generally you want to specify a path, independent of the home path.
That would mean
read "~/skits/slapstick/boguscalculus.mw"   , but this does not work. Any idea why ?
Furthermore using "currentdir" to set the current directory, I also have to use the full path from root "\" which is highly unusual.
Lastly given that I set a current directory with currentdir, how do I use the currentdir to read a file inside currentdir with read command ?
e.g.
currentdir "/home/harpo/skits"
how do I read the file in a worksheet using from the  currentdir
e.g. it should be
read "slapstick/boguscalculus.mw"
But that doesnt work either.
