Question: How to make dsolve work in Grid?
I first tried Threads and found that Maple dsolve does not work in threads (see https://www.mapleprimes.com/questions/239602-Error-in-Dsolve-Type-System-Does)
It was suggested there to use Grid instead of Threads.
Now I got time to try Grid. My first test shows that Grid does not work with dsolve also.
Here is an example where dsolve solves this system of odes,. But when using Grid, Maple gives an internal error
         Error, (in evalapply) cannot apply non-operator differential equation
Does this means one can't use Threads and also can't use Grid with dsolve? Or Am I doing something wrong?
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1841 and is the same as the version installed in this computer, created 2025, January 3, 8:59 hours Pacific Time.`
P:=[diff(x(t),t)=t*x(t)-y(t)+exp(t)*z(t),diff(y(t),t)=2*x(t)+t^2*y(t)-z(t),diff(z(t),t)=exp(-t)*x(t)+3*t*y(t)+t^3*z(t)]:
dsolve(P); #no error, Long answer
{x(t) = (exp(t)*y(t)*t^5-(diff(y(t), t))*exp(t)*t^3-2*(exp(t))^2*y(t)*t^2-(diff(y(t), t))*exp(t)*t^2+2*(diff(y(t), t))*(exp(t))^2+t*y(t)*exp(t)+(diff(diff(y(t), t), t))*exp(t)+2*exp(t)*y(t))/(-2*t^3*exp(t)+4*(exp(t))^2+2*exp(t)*t-1), y(t) = DESol({diff(diff(diff(_Y(t), t), t), t)+(-4*(exp(t))^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-2*(exp(t))^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-exp(t)/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-4*(exp(t))^3*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-2*(exp(t))^2*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-4*(exp(t))^3*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^2*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+exp(t)*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+2*(exp(t))^2*t^6/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+2*(exp(t))^2*t^5/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-4*(exp(t))^3*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+exp(t)*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+exp(t)*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t)))*(diff(diff(_Y(t), t), t))+(-4*(exp(t))^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-exp(t)/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-exp(t)*t^5/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^3*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-6*(exp(t))^2*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-exp(t)*t^4/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-2*(exp(t))^2*t^8/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-2*(exp(t))^2*t^7/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^3*t^5/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^3*t^4/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+2*(exp(t))^2*t^5/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^3*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-2*(exp(t))^2*t^4/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+2*(exp(t))^2*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*exp(t)*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+exp(t)*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t)))*(diff(_Y(t), t))+(-4*(exp(t))^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-8*(exp(t))^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-3*exp(t)/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+1/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-exp(t)*t^5/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-24*(exp(t))^4*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-8*(exp(t))^3*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^2*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-5*exp(t)*t^4/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-4*(exp(t))^3*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+16*(exp(t))^2*t^2/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*exp(t)*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+6*(exp(t))^2*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+2*(exp(t))^2*t^9/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-4*(exp(t))^3*t^6/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-6*(exp(t))^2*t^7/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+4*(exp(t))^2*t^6/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+20*(exp(t))^3*t^4/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+8*(exp(t))^2*t^5/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))+exp(t)*t^6/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-12*(exp(t))^3*t^3/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-4*(exp(t))^2*t^4/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t))-3*exp(t)*t/(-2*(exp(t))^2*t^3+4*(exp(t))^3+2*(exp(t))^2*t-exp(t)))*_Y(t)}, {_Y(t)}), z(t) = (2*exp(t)*y(t)*t^3-2*(diff(y(t), t))*exp(t)*t^2-2*(diff(y(t), t))*exp(t)*t+2*t*y(t)*exp(t)-t^2*y(t)+2*(diff(diff(y(t), t), t))*exp(t)+4*exp(t)*y(t)+diff(y(t), t))/(-2*t^3*exp(t)+4*(exp(t))^2+2*exp(t)*t-1)}
Grid:-Run(0,dsolve(P)); #gives internal error
Grid:-Wait();
This error happens on this specific ode. I tried 2-3 others and did not see an error. So it seems to depend to what the ode is.
Download dsolve_also_fail_in_grid.mw
