Question: Generating GUE Random Matrices and their eigenvalues - problems
I have been trying to do this for some while now but am not having much luck.
Basically what I need is a hermitian matrix, with real values on the diagonals X~N(0,1) and complex values on the off diagonals X~N(0,1/2)+i*N(0,1/2)
Obviously as its hermitian I need Xij = Xji*
I have tried a few things but can't get anything to work correctly, in my latest attempt I decided to try and construct the 2x2 case from scratch using if and for loops;
for i to n do
for j to n do
if i <> j then
A[i, j] := I*Generate(distribution(Normal(0, .5)));
A[j, i] := -A[i, j]; B[i, j] := Generate(distribution(Normal(0, .5)));
B[j, i] := B[i, j] end if;
if i = j then B[i, j] := Generate(distribution(Normal(0, 1))) end if
end do end do;
C := A+B
Where C gives me the hermitian matrix but when I try to work out the Eigenvalues using the maple command Eigenvalues(C) it gives me completely wrong values (gives complex numbers when should be real).
I have had this problem (Eigenvalue computation) with several other methods I have tried please can you help me find a way to make this work properly??
