Question: returning sorted function values with the input value shown
hi, i need help with some maple code.
i want to evaluate a function at a number of points from a set (i have done this using a loop), and then sort the resulting values in a set (done with the inbuilt sort function), and finally convert the sorted results back to their original values so i can establish which values give the highest and lowest function values.
if i use the solve function, i get more than one solution for each function value, but i only want the specific original value which led to that function value.
i hope this makes sense, thanks for any help!
