Question: Maple homework: desparately need help
1) compute the first ten derivatives of f(x)=sin(x)cos(x) using a for...do...od loop. Describe the pattern for the derivatives. Use your description to predict the 2500th derivative form. 2) Expand the do-loop code in the first question to include a command line inside the loop that plots each derivative. The output shows that each derivative is plotted separately. To plot the derivatives simultaneously after the loop has terminated, save the plot inside the loop using a label such as pl[i]:=plot(df[i],x=-10..10_. After the loop display all the plots together with the command below: >display(seq(pl[i],i=1..10)); Thank you sooooo much!
