Question: Calculating a given total using only given specific values tia sal22
Greetings All
I'm trying to figure out a way to calculate a given total
using only given specific values.
Example:
The total given is 46
The numbers I can use are 56,38,20,12,4, and 1
so the numbers it should use and come back with would be highest to lowest
so it should be 38,4,and 4.   Because these will add up to 46.  Is there a name given to this type of mathematics?  And does anyone have an example of how to do this?
tia sal22
