Question: How to import large amount of data from a .txt file into a vector on Maple12
I am trying to import about 1400 data entries from a .txt file in a vector. The file contains three columns of data, and I need to export only one of them. I tried using readdata command, however I get an error; I might not be specifying the path of the file correctly. What is the right way to specify the filename path using readdata command on mac? Apart from readdata command, are there any other options? Thanks in advance, SDK
