Question: How do I use the if statement in combination with 2 conditions
Hello, this is probably painfully simple but I cannot figure it out... so there it goes
there are four set of equations, but only one solution can be assigned to the parameter p (which is the outcome of R1, R2, R3, or R4).
1: if `and`(x4 = 0, x1 > 0) then assign(solpR1) end if;
2: if x2 = 0 then assign(solpR2) end if;
3: if `and`(x1 = 0, x4 = 0) then assign(solpR3) end if;
4: if `and`(x3 = 0, x1 = 0) then assign(solpR4) end if;
Note that my Maple notation for the equations that contain 'and' read as follows (somehow it gets changed with copy paste)
1: if x4=0 and x1>0 then assign(solpR1) end if;
3: if x1=0 and x4=0 then assign(solpR1) end if;
4: if x3=0 and if x1=0 then assign(solpR1) end if;
Since this connotation problem messes up a more complicated set of equations your feedback is more than appreciated!
