Question: too many levels of recusion
Hi everyone,
I've been tinkering with this problem for the past week but I'm suck :S!  I've tried google, mapleprimes, and the maple help file and nothing.
It's really a quite bizzare problem where I can use a procdure that I've defined... so long as I don't use it in a loop :S.
The procudure (called OVLM) takes 2 numbers as inputs and outputs an algebraic expression with 4 parameters as outputs.
Example:
> OVLM(3,7);
33)+(α77)+(α3+β7)
now if I do
> OVLM(1,1);
Maple gives me the answer no problem, but if I try putting that in even the simplest loop
> for i from 1 to 2 do
       OVLM(1,1)
    od;
Maple says "Error, (in type/algfun) too many levels of recusion".
So my question is, how do I increase the number of recusion levels that Maple allows?
Is there a way to increase the memory size or stack size that linux or windows allots for Maple?
Thanks in advance,
-Mike
