Question: Can someone solve this ?!?Crank-rocker
I´ve got problems with solving this task! Please help me with the solutions. Maybe someone knows how it works. I solved it from 1-4 and don´t know 5-8
Tim
The Crank - rocker consists of rocker 1, coupler 2 and rocker 4. It´s connected with swivel joints. The rack is fixed.
We look at the  point mass m in A and the torsion spring (with damper) in B0. The weight and the inert force because of the motion affect in A (vx,vy ax,ay). All other components are without mass, rotary inertia could also been disregarded.
For the "Resetmoment" in B0:
Mc = cT*(psi-psic0) + dT*dpsi/dt
against the rotation
For psi stands:
    psi = Pi-arctan(a*sin(phi), d-a*cos(phi))
arccos((1/2)*(d^2-2*d*a*cos(phi)+a^2+b^2-c^2)/(b*sqrt(d^2-2*d*a*cos(phi)+a^2)))
From the position of A:
rx = a cos(phi),   ry = a sin(phi)
speed:
drx/dphi = rx1 (y  appropriate)
acceleration
drx1/dphi = rx2 (y  appropriate)
angle speed:
dphi/dt = phip    "(phi)point"
angle acceleration:
d(phip)/dt = phipp   "(phi)pointpoint"
With this expressions stands:
vx = rx1*phip,   vy = ry1*phip,   ax = rx1*phipp + rx2*phip^2,  ay = ry1*phipp + ry2*phip^2
and we write the balance of the virtual performance
 -m*ax*rx1 - m*ay*ry1 - m*g*ry1 - ( cT*(psi-psic0) + dT*psi1*phi_p ) * psi1 = 0
TASK DESCRIPTION:
1. Differentiate the position/speed and Acceleration and write the equation of the acceleration. Set the paramter
{ a = 0.2 (m), b = 0.3, c = 0.4, d = 0.4, g = 9.81 (m/s^2), m = 1.3 (kg), cT = 2 (Nm/rad), dT = 0.4 (Nms/rad), psic0 = Pi/2 (rad) }
2. Set up the differential equation (DGL) in phi
3. Set up the equation of the static balance and find out a realistic stable layer.
    Set phi_stat=? and psi_stat in rad and degree! Hint: Plot the function to find the solution
4. Linearize the differential equation (DGL)  around the static balance (phi=phi_stat + Delta) for little oscillations around this balance position.
    Express the Differential equation only with delta
5. Identify the balance position out of this DGL angular frequency omega_0 of the undamped system
6. Calculate the own frequency (?) f in Hz of the undamped system and the "degree of dumping" theta (without dimension). (f=0.93965Hz)
7 . For a sinoid acceleration stimulation around the Axis A0 set and plot the frequency response for oscillations around the static balance position. mark the own-frequency omega_0.
8. Calclate the amplitude in [dB] for omega -->  and omega = omega_0View 8818_Crank-rocker Task.mw on MapleNet or Download 8818_Crank-rocker Task.mw
View file details
