Question: Sign of a polynomial
Hi -- I want to check the sign of a polynomial. Here's the polynomial expression (1/16)*(9*s^5-3*s^4*m-34*s^4*pa+12*s^3*m*pa+46*s^3*pa^2-18*s^2*m*pa^2-24*s^2*pa^3 +12*s*m*pa^3+s*pa^4-3*m*pa^4+2*pa^5-16*s^4+64*s^3*pa -96*s^2*pa^2+64*s*pa^3-16*pa^4+16*p^2*s+48*p^2*m-64*p^2*pa)/(s-pa)^4 and here's the parameterization: pa>s and pa>m. Generally checking the sign of the polynomial involves checking the signs of the factors...so, I'd like to factor the above expression. I haven't worked with "factor" much in Maple. Applying it as just factor(expr) with expr equal to the above expression does nothing. So not sure the best approach. Thanks!
