Question: How do I compile the OpenMaple example omexample.c using Dev-C++?
I am trying to compile the OpenMaple example omexample.c using Bloodshed Dev-C++, but I am getting linker errors. I have tried adding maplec.lib to the linker parameters under project options, and I have also tried copying the library to my working directory and passing it as a compiler command option. Neither has worked. Thanks in advance for your help. Regards, layne
