Question: Re: My "Help,printing problem" post.
I have done a lot of experimenting since my post of 13 hours ago and now have a better handle on the print problem. I am using an HP2110 printer. When I try to print out a document OR work sheet that I originated on maple, I click on file, select print, and on the resulting pop-up menu select properties. There are now 4 choices for print quality: Best, Normal, Everyday, and Fast Draft. If I select "Every Day" the print out will have letters (and graphs) that are twice the size that they should be. Then if I do the same exact thing, without changing anything except selecting one of the other print quality choices, the resulting print out is normal. In fact it is normal for any of the print quality choices except "Every Day." That would make one think that there is something wrong with my printer but I don't have this problem when I print out documents from my word processor so the problem is clearly related to the Maple program. Perhaps it is a mistake in the maple software. Should I bring this to someones attention at Maple? If so, who? Thank you.
