Question: How do i create a library with the assistant
Hello, i'm in need of some help. I'm searching how to use the library browser to create a module usable with with(). In fact i have to learn how to add or remove function to an existing library. And when i use the assistant, i see int the window a module and when i double click on the module i enter in it and i can see the fonction inside it. But when i add some functions in .m files the assistant add them in the root and not in the module. To express it clearly watch the figure Module And i want Module | | | --- function1 |---function 1 |---function 2 and with the assistant i obtain function 2 Module | |---function1 But if you can help me just to show me how to create a module usable with with from nothig it would be very helpfull too. Thanks a lot
