Question: help about equation solving
hi all, i have an equation like this: a = Lambda[d]/(Lambda[d] + Lambda[in]); P(0, 0) = 1/(k + (Lambda[in] / Mu[in]) * (k - 1) + (Lambda[in] / Mu[m]) * (k - 1) + a* ((1 - a^(n - k)) / (1 - a)) + (Lambda[in] / Mu[in])* a * ((1 - a^(n - k)) / (1 - a)) + (Lambda[in] / Mu[M]) * a * (( 1 - a^(n - k)) / (1 - a)) + (Lambda[d] / Mu[D]) * a^(n - k)) Availability (A) = P(0,0)*(k + (a * (1-a^(n-k)))) i want to find the optimal Lambda[in] which max the A.. is there any non-numeric solution way and plot A-Lambda[in] graph? i try to solve in maple 10 i derivate A with respect to Lambda[in] and then i'm confused... and if i couldn't solve it in closed-form i give some numeric values and use solve function to find Lambda[in] which max A..is this a correct way? thanks...
