Question: Surface Coloring
Question:Surface Coloring
Nasos 84 Maple
Hi, Im using the display command to plot 3d surefaces/projections (which the also overlap on different occasions)on the same graph coming from different equations. My question is how can i colour the surfaces with a command (its too hard to do it onthe graph)so i know to which equation each surface corresponds to? Is there an additional way offered from maple to distinuish the graphs from each other. Finaly, I use the command labels=[x,y,z] to call my axis "Time of Fault Clearance,s" , "Magnitude of Fault Current" , "Parametr".How do i syntax a string? Thanks for your time
