Question: Collapse document block
The enclosed file has 2 document blocks. As far as I can tell, each block is identical except for the name of a procedure defined in it. When I go into Block A and select Format/Collapse Document Block, the procedure does not disappear. When I go into block B, it does. I'd appreciate it if someone could tell me why the difference. -Thanks View 2292_Georgeworksheet15.mw on MapleNet or Download 2292_Georgeworksheet15.mw
View file details
