Question: Change Variable Names using the Edit/replace command.
Hello. I am aware of the subs command. I was wondering if there is any way in Maple to use Edit/replace to change variable names. Whenever I do a search on 'II' in the following file, it takes me the the line which starts with "In this line". It seems to ignore the Math stuff. Any way around this? Second question: To get the line with the second derivative to print out the wat it did, I ended up having to use 2 sets of single quotes around the formula instead of one. I was kind of wondering why that is. -Thanks.
Maple Equation
Maple Equation
Maple Equation
Maple Equation
Maple Equation
Maple Equation
In this line I will write II
This post was generated using the MaplePrimes File Manager
Download the original worksheet | View worksheet on MapleNet
