Question: upper limit on "delay" options for plotter?
When using the Plotter element in a Maplet, one of the options is (copied from the help file): delay = posint The delay in milliseconds between frames. The default value for this option is 100. So far, if I set this above 1000, the animation will not play. 1000 works and anything below it. Does this mean I cannot have my animation play slower than one second intervals between frames? If this is the upper limit, does anyone have a suggestion for how to get around this? One thing I was thinking was using the Student[Calculus1][ApproximateInt] command (this is what I'm animating) with the partition value set at different intervals corresponding to a function, t, 2*t, 4*t, etc., just like the actual animation does. But I could have my plotter updated manually using a time delay function that Will gave me previously on here. That's a lot of extra code, though; delaying the plot speed even more would work much better. Thanks for any help.
