Question: Reverse y-axis direction
In structural engineering the y-axis direction in beam deflection calculations is reversed. A negetive deflection is an upward deflection. I need to plot the deflection. A simple reflect command will do part of the trick, but the tickmarks are not reflected. How do I reverse the y-axis direction so it will be negetive to positive from top to bottom? Thanks.
