Question: more data points on my numerical solution plot
I am solving a set of differential equations using the following command, numericalsol:=dsolve({ODEsys, ics}, numeric, method=rkf45) and I'm plotting my numerical solution using the following command, plots[odeplot](numericalsol,[t,w[1](t)],0..20); But when the solution is plotted the graph looks jagged and not smooth at all. I'm assuming that I am not getting enough points in my numerical solution and that's whats causing the problem. Is there any way to get more points so that my plot will look smooth?
