How to show that any Pythagorean triplet can be obtained from <3,4,5> ? Thank you.
Can we simplify this program?
#Génération Géométrique et Algébrique des triplets Pythagoriciens
with(geometry);
with(LinearAlgebra);
_EnvHorizomtalName = 'x';
_EnvVerticalName = 'y';
with(plottools);
P := point([0, 0], color = black, symbol = cross, symbolsize = 25);
Oo := point([1/2, 1/2], color = black, symbol = cross, symbolsize = 25);
A := point([1, 1/2], color = black, symbol = cross, symbolsize = 25);
c1 := circle([1/2, 1/2], 1/2, color = blue);
NULL;
PA := line([0, 0], [1, 1/2], color = red);
eqC := (x - 1/2)^2 + (y - 1/2)^2 = 1/4;
eqPA := y = 1/2*x;
sol := solve({eqC, eqPA}, {x, y});
t1 := textplot([0, 0, 'typeset'("P"), font = [Times, Bold, 14]], 'align' = 'above');
t2 := textplot([1, 1/2, 'typeset'("A"), font = [Times, Bold, 14]], 'align' = 'right');
t3 := textplot([1/5, 1/10, 'typeset'("A'"), font = [Times, Bold, 14]], 'align' = 'above');
A1 := point([1 - 1/5, 1/10], color = black, symbol = cross, symbolsize = 25);
diff(A, x) := point([1/5, 1/10], color = black, symbol = cross, symbolsize = 25);
t4 := textplot([1 - 1/5, 1/10, 'typeset'("A1"), font = [Times, Bold, 14]], 'align' = 'right');
A2 := point([1 - 1/5, 1 - 1/10], color = black, symbol = cross, symbolsize = 25);
t5 := textplot([1 - 1/5, 1 - 1/10, 'typeset'("A2"), font = [Times, Bold, 14]], 'align' = 'right');
A3 := point([1/5, 1 - 1/10], color = black, symbol = cross, symbolsize = 25);
t6 := textplot([1/5, 1 - 1/10, 'typeset'("A3"), font = [Times, Bold, 14]], 'align' = 'right');
poly := Matrix([[1/5, 1/10], [1 - 1/5, 1/10], [1 - 1/5, 1 - 1/10], [1/5, 1 - 1/10]], datatype = float);
pol := polygonplot(poly, color = blue, transparency = 0.95);
display(c1, P, Oo, A, PA, seq(A || i, i = 1 .. 3), seq(t || i, i = 1 .. 6), pol, scaling = constrained, axes = none, size = [600, 600]);
R1 := Transpose(<<1, -2, 2> | <2, -1, 2> | <2, -2, 3>>);
R2 := Transpose(<<1, 2, 2> | <2, 1, 2> | <2, 2, 3>>);
R3 := Transpose(<<-1, 2, 2> | <-2, 1, 2> | <-2, 2, 3>>);
V := <3, 4, 5>;
MatrixVectorMultiply(R1, V);
MatrixVectorMultiply(R2, V);
MatrixVectorMultiply(R3, V);
t1 := <2225, 3648, 4273>;
t2 := MatrixVectorMultiply(1/R1, t1);
t3 := MatrixVectorMultiply(1/R3, t2);
t4 := MatrixVectorMultiply(1/R2, t3);
t5 := MatrixVectorMultiply(1/R1, t4);
t6 := MatrixVectorMultiply(1/R3, t5);
MatrixVectorMultiply(MatrixMatrixMultiply(MatrixMatrixMultiply(MatrixMatrixMultiply(MatrixMatrixMultiply(R1, R3), R2), R1), R3), V);
% - t1;
NULL;
The question is not at all from me, but, probably, one might say, from the authors of this publication.  interesting_system.pdf
Just for fun.
Find all real solutions to this 2x2 system of nonlinear equations in any given domain.
f1:=x1-x1*sin(x1+5x2)-x2*cos(5x1-x2);
f2:=x2-x2*sin(5x1-3x2)+x1*cos(3x1+5x2);
In my view, <x || (1 .. 2); y || (1 .. 2); 1 $ 2> should return a Matrix without any error messages; however,
<x || (1 .. 2); y || (1 .. 2); 1 $ 2>; # Arguments are shielded???
Error, (in Matrix) this entry is too wide or too narrow: 1
If I understand right, each argument of a function is evaluated in turn (unless the modifier is used).
So why is it not equivalent to <x1, x2; y1, y2; 1, 1>
As I learned here Maple is also a multi-paradigm programming language.
I was wondering how Maple compares in this chart.
Even though I am not a computer scientist, I would say that Maple is on a par with the number one (not sure about pipelines).
Would this claim be correct?
I'm using Maple 18. I have a problem that I can't solve. It concerns the programmatic - from the Maple code level - export of animations (even single images) with good quality graphics, i.e. either high resolution or "large" size - which translates into the same. This is because Maple 18 does not have a size option in plot3d.
Even manually enlarged graphics - a bit too much, makes manual export impossible; Maple reports "..the file could not be created...". Most often, this ends with the creation of a gif file with a capacity of 0 bytes.
I am asking for help if anyone knows how to deal with this [normal export of "normal" graphics manually or with software can of course be done in Maple 18].
Regards.
Through the years I basically had to work with the fact that Maple prefers to express results in terms on Cos^2(x) and not Sin^2(x).
With older Maple versions there was never a workaround by means of a command that would convert an expression in terms of sin^2(x) if Maple expressed it as cos^2x.
Is there any way in the newer Maple versions to convert output to be expressed rather as sin(x).
It becomes a bit old, to always substitute the identitity manually to convert.
Any easy way  for this in new versions.
I have a table indexed as A[i][j,k],  Each entry is an expression involving diff which I want to convert to but convert(A,D) doesn't work. Any suggestions on how to do that?
for i from 1 to 2 do
  for j from 1 to 2 do
    for k from 1 to 2 do
      A[i][j,k] := diff(u[i](x[1],x[2]), x[j], x[k]);
    end do
A[1][1,1];
diff(diff(u[1](x[1], x[2]), x[1]), x[1])
print(A);
A
Download convert-table.mw
I am trying to find the minimum values of a table, but not of all of its indices, just some that comply to a certain pattern.
The minimum of the values of a table are found by using min(entries(atable)).
If the indices of atable are "a1", "a2", "b1", "b2", I would like to just have the ones starting with "a".
Can be done by a loop, but is there a easier way?
I any trying to seperate the real and imaginary components but they are mixed up inside and outside a square root.
Their seems to be a problem displaying the worksheet.
expand((a+I*b)*(a-I*b))
(a+I*b)+(a-I*b)
# z = x *Iy    I need to seperate out solution to [x,y] & [x,-y]
#https://math.stackexchange.com/questions/44391/foci-of-a-general-conic-equation
eq := T*z^2 - (R + S*I)*z +G-K + H*I
sol:=solve(eq,z)
expand(sol[1]*sol[2])=a^2+b^2
simplify(sol[1]+sol[2]=2*a)
simplify(sol[1]-sol[2]=2*b)
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/2024-04-20_Q_Seperate_Real_&_Imaginary.mw .
Download 2024-04-20_Q_Seperate_Real_&_Imaginary.mw
Is it wrong to call limit like this
limit(expr,[y = y0,x=x0]);
vs
limit(expr,y = y0);
limit(%,x=x0);
The first one gives internal Maple error.  Worksheet attached. I would have expected both to work the same.
`The "Physics Updates" version in the MapleCloud is 1727 and is the same as the version installed in this computer, created 2024, April 17, 19:33 hours Pacific Time.`
kernelopts('assertlevel'=2):
expr:=3/2*(y-1)^(2/3)-3/2*x^2-c__1 = 0;
y0:=-7;
x0:=3;
(3/2)*(y-1)^(2/3)-(3/2)*x^2-c__1 = 0
-7
Error, (in limit/multi/ldegree1) assertion failed
y0:=-7;
x0:=3;
limit(expr,y = y0);
limit(%,x=x0);
-7
-3+(3*I)*3^(1/2)-(3/2)*x^2-c__1 = 0
-33/2+(3*I)*3^(1/2)-c__1 = 0
Download limit_internal_error_maple_2024.mw
Hi all, I have two versions Maple 2016 and Maple 2018. I'm writing a program, but some functions only run on Maple 2018, so I'm trying to find a way to check the version of Maple. How can I do this?
I have noticed a substantial difference between the memory Maple displays per worksheet
and what the task manager (red arrow) indicates. After kernel restart it looks like this
What Maple displays does not seem to correlate with the physical memory used/allocated.
What is actually displayed and how can we make use of this information?
Also: Is the displayed Time the total process time or the time the Gui waits for the server to reply? Hard to tell.
I'm encountering an issue with the "roots of complex number" message while running my Maple code. Maple seems unable to solve this problem for me.
I would greatly appreciate any ideas or suggestions that could help me resolve this error.
Vib-code.mw
I still see these Maple internal errors in Maple 2024.
Now calling odetest.
The problem is that it is not possible to catch them.
Any suggestion what to do and what causes it?
11196
sol:=y(x) = (exp(RootOf(-sin(x)*tanh(1/2*_Z+1/2*c__1)^2+sin(x)+exp(_Z)))+sin(x))/sin(x);
ode:=diff(y(x),x)-cot(x)*(y(x)^(1/2)-y(x)) = 0;
y(x) = (exp(RootOf(-sin(x)*tanh((1/2)*_Z+(1/2)*c__1)^2+sin(x)+exp(_Z)))+sin(x))/sin(x)
diff(y(x), x)-cot(x)*(y(x)^(1/2)-y(x)) = 0
try
   odetest(sol,ode,y(x));
catch:
   print("cought error ");
end try;
Error, (in anonymous procedure called from depends) too many levels of recursion
Download too_many_levels_of_recursion_calling_odetest_maple_2024.mw
Hello:
I have created a simple plot and labelled a line as follows
Lbl:=plots[textplot]([600,-Pi*floor(R)*ln(R)-0.01,typeset(-pi*floor(r)*ln(r)),font=[Helvitica,bold,10]],labels=[T," "]):
where R is a number, so the label appears near where I want it to be:
But part of the formula is floor(r) and I can't make that appear as the 2D mathematical symbol for floor(r) in the typeset;
If I make the typeset part of an axis label or a legend, I can cut and paste the math2 expression for floor(r) just before I export the plot and that works, but how do I do that for a textplot that is sitting in the middle of a plot?
First 112 113 114 115 116 117 118 Last Page 114 of 2427
