In Maple 2022
res := t^3 - 3*t^2*sqrt(t^2*(12*sqrt(2)*ln(t) + 9*ln(t)^2 + 8)^(1/3))*ln(t)/(12*sqrt(2)*ln(t) + 9*ln(t)^2 + 8)^(2/3) - 2*t^2*sqrt(t^2*(12*sqrt(2)*ln(t) + 9*ln(t)^2 + 8)^(1/3))*sqrt(2)/(12*sqrt(2)*ln(t) + 9*ln(t)^2 + 8)^(2/3);
plot(res,t=-5..1)
gives
The same exact code in Maple 2024 gives
Worksheet is below.
Both on same PC. Windows 10.
Will report to Maplesoft, but thought to check also here is others have seen such problem before.
Btw, Maple 2022 plot is the correct one.
14900
`The "Physics Updates" version in the MapleCloud is 1700. The version installed in this computer is 1693 created 2024, March 7, 17:27 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
plot(res,t=-5..1)
t^3-3*t^2*(t^2*(12*2^(1/2)*ln(t)+9*ln(t)^2+8)^(1/3))^(1/2)*ln(t)/(12*2^(1/2)*ln(t)+9*ln(t)^2+8)^(2/3)-2*t^2*(t^2*(12*2^(1/2)*ln(t)+9*ln(t)^2+8)^(1/3))^(1/2)*2^(1/2)/(12*2^(1/2)*ln(t)+9*ln(t)^2+8)^(2/3)
Download wrong_plot_V_2024_march_15_2024.mw
Maple's coulditbe  is useful. But unfortunately it does not return back to the user the conditions under which the proposition was found true. This could make it much more useful. It seems in way similar to Mathematica' Reduce but Reduce returns the conditions.
Is there a way to find the conditions which makes it true?
I use coulditbe alot. I use it to verify that the result of odetest (I call it the residue) is zero or not. Maytimes, odetest does not return zero. And using simplify, or evalb or is to check if the residue is zero, all fail. But many times, coulditbe returns true, meaning the residue is zero. But I do not know under what conditions. In Mathematica's Reduce, it tells me the conditions.
Here is one of hundreds of examples I have
ode:=(t^3+y(t)^2*sqrt(t^2+y(t)^2))-(t*y(t)*sqrt(t^2+y(t)^2))*diff(y(t),t)=0;
ic:=y(1)=1;
sol:=dsolve([ode,ic]);
the_residue:=odetest(sol,[ode,ic]);
You see, odetest says it could not verify the solution (the first entry above) but it did verify the solution against the initial conditions.
Using simplify, evalb and is all also could not verify it
simplify(the_residue[1]);
evalb(the_residue[1]=0);
is(the_residue[1]=0);
Now coulditbe does:
_EnvTry:='hard':
coulditbe(the_residue[1]=0);
So the solution is correct, but I do not know under what conditions. Using Mathematica's Reduce I can find this:
So now back in Maple, I can do this
simplify(the_residue[1]) assuming t>exp(-2*sqrt(2)/3);
Actually in this example, just using assume t>0 also gives zero. But I am using Mathematica's result for illustration.
You might ask, why do I need to know for what values of the independent variable is the residue zero?
Because in some cases, the residue is zero only at single point! So it does not make sense to say the solution is verified to be correct only at one single point of the domain, right?
it needs to be some finite range at least. Here is an example of an ode whose solution is correct only at x=0
ode:=diff(y(x),x)=3*x*(y(x)-1)^(1/3);
ic:=y(3)=-7;
And simplify, evalb, is all fail to verifiy this, but coulditbe says true
_EnvTry:='hard':
So now, we ask, is this solution then correct or not? It turns out to be zero but only at origin x=0
plot(abs(the_residue[1]),x=-1..1)
If I knew that residue is zero only at single point, then I would say this solution is not correct, right?
And that is why I need to know under what conditions coulditbe retruned true.
I tried infolevel[coulditbe]:=5 but nothing more was displayed on the screen.
Mathematica's Reduce confirms that when x=0 the residue is zero.
So my question is simply this: Can one obtain the conditions used by coulditbe to determine when result is true?
It will be useful if Maple could in future version return the value/range which makes it true.
Hope this is a simple question to answer but how do you use units and show 1 of something without losing the 1.  For example, it's easy enough to show 3 hours as 3h but nobody writes 1 hour as "h".  It's just silly.  Is there a way for 1 hour to render as "1h"?  Really the question is can you get 1 of any unit to show as "1 unit" and not just "unit"? Thanks.
I asked a question a while ago
https://www.mapleprimes.com/questions/235734-How-Can-The-Functional-Derivativevariation
Which did not get any immediate responses but one late one which i had replied to, but nothing else since then.
Is it appropriate to delete and repost and try to get more responses/exposure and see if anyone else has any ideas?
Since @ecterrab is the one who responded I consider this an interesting problem that I would like to continue discussing.
I am trying to convert from MapleSim to Simulink Matlab by using the S-function code Generation connector, but I got the above message when I uploaded the selected subsystem and I have no idea how can I fix it. Please help me
I am trying to implement the algorithms given in this paper (free for download) in Maple 2015
https://www.researchgate.net/publication/374636058_A_simple_algorithm_for_computing_a_multi-dimensional_the_Sierpinski_space-filling_curve_generalization
Such algorithms, apparently very easy, provides an approximation of  a sapce-filling curve and its pseudo-inverse. I am interesting in this space--filling curve for its properties. Please, find attached the Maple file, I am not sure if the code of the paper is not fine or I am doing something wrong.
Many thanks un advsnce for your help
Sierp_v1.mw
p1>0, p2<0 and x[0] are arbitrary constants. How can i solve this integral?
   I want to see
thanks in advance.
First of all, I'm beginner in Maple.
I want to plot  "M" versus "kc" and "deltah" as a 3D curve (M is real and positive). Intervals of kc and deltah are  given (see attached file). These three parameters (i.e, M,kc,deltah) should satisfiy the following equation:
Eq=-(1-(deltab+deltah))-(1-(deltab+deltah))/(kc-3/2)-deltah/sigmah-deltah/(sigmah*(kh-3/2))-(1/6)*deltab*sqrt(3)*mu*(1/sqrt((M-u0b+sqrt(3)*sqrt(mu*sigmab))**2)+1/sqrt((M-u0b-sqrt(3)*sqrt(mu*sigmab))**2))/sqrt(mu*sigmab)-(1/6)*sqrt(3)*(1/sqrt((M+sqrt(3)*sqrt(sigmai))**2)-1/sqrt((M-sqrt(3)*sqrt(sigmai))**2))/sqrt(sigmai)=0.
Other parameters are as follows:
 kh=3, sigmah=4,sigmab=1,u0b=0.05,sigmai=1/300,deltab=1e-6,mu=1836.
3D.mw
How to solve and plot a ODE system in RK method.
eq1 := diff(f(x), x, x, x)-(1/2)*Sc*sin(alpha)*g(x)*(diff(g(x), x, x))+(1/2)*x*cos(alpha)*(diff(f(x), x, x))+(1/2)*sin(alpha)*f(x)*(diff(f(x), x, x)) = 0; eq2 := (diff(g(x), x, x, x))/Pm+(1/2)*x*cos(alpha)*(diff(g(x), x, x))+sin(alpha)*f(x)*(diff(g(x), x, x))-sin(alpha)*(diff(f(x), x, x))*g(x) = 0; eq3 := (diff(theta(x), x, x))/Pr+(1/2)*x*cos(alpha)*(diff(theta(x), x))+(1/2)*x*(diff(f(x), x))*(diff(theta(x), x))+sin(alpha)*(x*(diff(f(x), x))-f(x))*(diff(theta(x), x))-Nb*(diff(s(x), x))*(diff(theta(x), x))-Nt*(diff(theta(x), x))^2+(1/4)*Sc*Br*sin(alpha)^2*(diff(f(x), x))^2*(x*(diff(g(x), x))-g(x))+(diff(g(x), x))^2*(x*(diff(f(x), x))-f(x)) = 0; eq4 := diff(s(x), x, x)+S*((1/2)*cos(alpha)*x*(diff(s(x), x))+(1/2)*sin(alpha)*f(x)*(diff(s(x), x)))+Nt*(diff(theta(x), x, x))/Nb = 0
ics := f(0) = 0, (D(f))(0) = 1, g(0) = 0, (D(g))(0) = 1, theta(0) = 1, s(0) = 1; bcs := (D(f))(100) = 0, (D(g))(100) = 0, theta(100) = 0, s(100) = 0
alpha = - 30 degree, Sc = 1.0, Pm = .1, Pr = 6.2, Nb = .1, Nt = .1, Br = .5, S = 1
I would like to create/import a list from a text-file. The text-file "example.txt" has the following structur:
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
10 12
11 14
On every line are two numbers, separated by a space. The list should contain only the second number, in this example
L:=[1, 2, 3, 4, 5, 6, 7, 8, 9, 12, 14].
The original text-file has 12615 lines, the biggest number is around  3.126 * 10^139.
Thanks for your help.
Was working with some antenna design equations and noticed that in a certain plot definition, the addition of gridlines changes the shape of the plotted curve.  Is this a bug or is there something obvious here that I am overlooking?  This one really has me scratching my head.  The only difference between the two plots below is the addition of the gridline spec.
Many thanks!
gridlines_change_plot.mw
I'm currently exploring the properties of a sum in Maple, and I was wondering how to obtain the values of the following sum:
sum 1/(i*j*k*) such that 1<=i+j+k<= n
I'm interested in the values of this sum for a given n. How can I express this efficiently in Maple?
Hi, I have an homework where I need to find the highest point and the lowest point on an ellipse form by the intersection of two equations wich are 4x-3y+8z=5 and z^2=x^2+y^2 and I have to use the LagrangeMultiplier command. I get how it works but I can't get the correct form. How should I do it ?
Is it possible overlay one column graph on top of another ? And if, how do I do it?
I have here a function
                           "sin(x)/x"
and suppose sin(x)/x = 0
Can I now use MapleAI to retrieve the correct command for this in Maple..could I?
The intersection points with the x-axis are positive and negative multiples of Pi
I have put these in an ordered list, but Maple gives this:
For x domain = -20...20
X := {x = Pi}, {x = 2*Pi}, {x = 3*Pi}, {x = 4*Pi}, {x = 5*Pi}, {x = 6*Pi}, {x = -6*Pi}, {x = -5*Pi}, {x = -4*Pi}, {x = -3*Pi}, {x = -2*Pi}, {x = -Pi};
X := sort(eval~(x, [X]));
 X := [, -6 Pi, -5 Pi, -4 Pi, -3 Pi, -2 Pi, -Pi, 2 Pi, 3 Pi, 4 Pi, 5 Pi, 6 Pi]
A strange ranking that Maple comes up with ?
with(NaturalLanguage);
        [Explain, GetCommand, GetMath, Query, RawQuery]
GetCommand("give for Maple solve command all options?");
            "solve(equations, variables, options);"
Explain("give for Maple solve command all options?");
"Maple is a symbolic and numeric computing environment. Its
   "solve" command is used to find solutions (roots) of a given
   equation or a system of equations.
  There are a number of options (or "parameters") which can be
   specified in this command to alter its behavior:
  1. `Allsolutions`: This option makes Maple to generate all
   possible solutions of an equation.
  2. `Real`: This option only provides the real solutions. If
   equations do not have real solutions, it will return an
   empty set.
  3. `Positive`: It only includes positive solutions in the
   output.
  4. `explicit`: If specified, Maple attempts to isolate roots
   and provide an explicit solution for each variable.
  5. `assume = real`: This option restrict the solutions to
   only real numbers.
  6. `parametric`: This option allows Maple to write the
   solutions in a parametric form.
  7. `avoid ={x = a}`: This option makes solve exclude the
   possibility `x = a` as a solution.
  8. `MaxDegree = d`: This option allows you to limit the
   degree of the polynomial equations to be considered.
  9. `maxdepth = d`: This sets a limit on recursive depth to
   which the computation should go to seek a solution.
  10. `multiplicities`: This option reports multiplicity of the
   roots.
  11. `solutions = vars`: This option tells Maple to look for
   solutions for specific variables.
  12. `numeric`: This option makes solve find a numeric
   solution to the equation.
  13. `symbolic`: This option makes solve find a symbolic
  14. `simplify`: This option simplifies the solutions returned
   by solve.
  15. `sqrt`: This option allows square roots in the output.
  It is important to note that not all options are suited for
   use with all types of equations. Also, the "solve" command
   in Maple can be occasionally limited by the complexity of
   the equation, and may sometimes fail to find solutions that
   more specialized software or methods can find."
First 122 123 124 125 126 127 128 Last Page 124 of 2427
