Applying Maple 2023's dsolve to the ODE shown below yields the solution y(t)=0 which is obviously incorrect.  Maple 2021 and earlier used to give a nonzero (albeit not very useful) answer.
F := (t-1)*(t-2)/(t^2+1)^3*(Heaviside(t-2)-Heaviside(t-1));
(t-1)*(t-2)*(Heaviside(t-2)-Heaviside(t-1))/(t^2+1)^3
plot(F, t=0..4);
de := diff(y(t),t,t) + diff(y(t),t) = F;
diff(diff(y(t), t), t)+diff(y(t), t) = (t-1)*(t-2)*(Heaviside(t-2)-Heaviside(t-1))/(t^2+1)^3
ic := y(0)=0, D(y)(0)=0;
y(0) = 0, (D(y))(0) = 0
Huh?
dsolve({de,ic}, y(t));
y(t) = 0
Specifying method=laplace will make that work, but how is an
unsuspecting user to know that what's obtained above is incorrect?
Download dsolve-bug.mw
I have a problem. Maple wants to create and a palette, I can add content and icons to the palette, but as soon as I restart Maple, the palette content has disappeared and says that Maple cannot find the added icons.
I have used the method described in Maple Help.
Is there anyone who can help?
Kind regards
Dear sir ,
I have implemented Dsolve method the code was executed, but i need to apply Kellor Box method to solve the ODES
Please can any one help how to implement?
because there is no post regarding the Kellor box method.
restart; with(plots)
S := 1; Rd := .1; delta := .1; Hs := 1; Sc := .1; Pr := 6.8; n := 1; Rc := .1; E := .1; M := 1
OdeSys := a1*(diff(f(eta), eta, eta, eta, eta))/a2-S*(3*(diff(f(eta), eta, eta))+eta*(diff(f(eta), eta, eta, eta))+(diff(f(eta), eta))*(diff(f(eta), eta, eta))-f(eta)*(diff(f(eta), eta, eta, eta)))-a5*M*(diff(f(eta), eta, eta))/a2-a1*Kp*(diff(f(eta), eta, eta))/a2 = 0, (a4+4*Rd)*(diff(Theta(eta), eta, eta))+12*Rd*delta*((diff(Theta(eta), eta))*(diff(Theta(eta), eta))+Theta(eta)*(diff(Theta(eta), eta, eta)))+Hs*Theta(eta)-a3*Pr*S*(diff(Theta(eta), eta))*(eta-f(eta)) = 0, diff(Phi(eta), eta, eta)-S*Sc*(diff(Phi(eta), eta))*(eta-f(eta))-Sc*Rc*(1+delta*Theta(eta))^n*Phi(eta)*exp(-E/(1+delta*Theta(eta))) = 0; Cond := f(0) = 0, ((D@@2)(f))(0) = 0, (D(Theta))(0) = 0, (D(Phi))(0) = 0, f(1) = 1, (D(f))(1) = 0, Theta(1) = 1, Phi(1) = 1
KpVals := [1, 2, 3, 4]
for j to numelems(KpVals) do Ans[j] := dsolve(eval([OdeSys, Cond], Kp = KpVals[j]), numeric, output = listprocedure) end do
 cols := [red, blue, black,green]:
 plotA:= display
  ( [ seq
      ( odeplot
        ( Ans[k],[eta,(f(eta))],
          eta=0..1,
          color=cols[k]
        k=1..numelems(KpVals)
    ],linestyle = "solid",
    'axes'= 'boxed',labels=[eta,'f(eta)'],labelfont=[TIMES,BOLD,16]
plotB:= display( [ seq( odeplot
        ( Ans[k],[eta,Theta(eta)],
          eta=0..1,
          color=cols[k]
    'axes'= 'boxed',labels=[eta,'Phi(eta)'],labelfont=[TIMES,BOLD,16]
plotC:= display( [ seq( odeplot
        ( Ans[k],[eta,Phi(eta)],
          eta=0..1,
          color=cols[k]
 plotA:= display
  ( [ seq
      ( odeplot
        ( Ans[k],[eta,(diff(f(eta),eta))],
          eta=0..1,
          color=cols[k]
    'axes'= 'boxed',labels=[eta,"f '(eta)"],labelfont=[TIMES,BOLD,16]
Download kellor_box_method.mw
Is there an equivalent to Pivot Table in Excel?
I'm working on some investing data, and am using Maple to gather information from various sources and using DataFrame to combine all the data. I could export the dataframe and open in Excel or other spreadsheet and use the Pivot table to summarize the data, but is there an easy way to do all of it in Maple?
Good evening,could you please help me to find the values of Phi[2],Phi[3],Phi[4],....
The right hand side of the for loop is the equation i need.Is this maple code correct.
rps1.mw
Hi,I am looking to construct a histogram in an aesthetic manner with bins. The Histogram command does not provide an optimal output. Any suggestions? Thanks QHistogram.mw
Assuming u and v are both real, I want to prove this equality.
int(Dirac(u-v), [u, v])  = min(u, v)
To be clear, I don't want to verify is this equality is true, but I want (I would like) to do is to get its rhs by using ad hoc transformations of its lhs.
Under the same assumptions, how can I do the same thing for this equality?
int(Dirac(u+v-1), [u, v]) = max(u+v-1, 0)
many times I have an expression with constant of integrations in it and need to integrate., So need to make sure to add a new constant of integration which is not already used.
Currently I do this
sol:=x-_C1*x+_C3*x^2;
myconstants:=indets(sol,And(symbol, suffixed(_C, nonnegint)));
map(X->String(X),myconstants);
map(X->X[3..],%);
map(X->:-parse(X),%);
n:=max(%);
new_constant:=_C||(n+1);
This make _C4 as the new constant.
This assumes all constants have form _Cn which is what I use. It finds all _Cn's then converts each to string, then remove _C part from the string leaving the number, then find the maximum one and adds 1 to it to generate new constant to use,
Is there a better way to do this? Even though the above works, I have feeling there might be better way.
I am using Maple 2023 on a Mac. When I issue the following commands
for j to 10 do
    pl || j := plot(sin(j*x)^j, x = 0 .. 5);
display([pl || (1 .. 10)], insequence = true);
I used to get an animation but also some controls: I could easily repeat, reverse, change FPS, etc. Now I seem to have to go Format_>Plot->Animate->Play. Has there been a change in Maple or have set some preference to this awkward form? I admit I have not been using Maple a lot these last couple of years.
3*alpha*a^2*B*cos(3*Phi)/(4*omega[0])-f*cos(Phi)/(2*omega[0]) = sigma*a-3*alpha*a*B^2/omega[0]-3*alpha*a^3/(8*omega[0])
I would like to get a (necessary and sufficient) condition on real parameters a, b, and c for which there exists (at least) one non-negative solution to 9*x**4 + c < 9*a*(x - 1) + 3*b*(x**2 - 1) + c*x**3
A convenient way to formulate this is using quantifiers. Unfortunately, if I run
QuantifierElimination:-QuantifierEliminate(:-exists([x],:-And(x>=0,9*x^4+c<9*a*(x-1)+3*b*(x^2-1)+c*x^3)));
Maple will simply output
Error, (in RootFinding:-RSGateway:-refine_uni_tri) invalid input: RootFinding:-RSGateway:-try_refine_iso_tri expects its 1st argument, box, to be of type nonemptylist([rational, rational]), but received [8019*x^2+(-9*v__2^2-96552*v__2-279834912)*x+49*v__2^3+78318*v__2^2-387436932*v__2+121801800168, v__2^4+2052*v__2^3-5536296*v__2^2+3575222064*v__2-710903793888]
As an alternative method, one can execute
RealDomain:-solve([x >= 0, 9*x**4 + c < 9*a*(x - 1) + 3*b*(x**2 - 1) + c*x**3], 'parameters' = {a, b, c});
Regretfully, this time the computation is not done in several minutes (so one may have to abort it manually).
So, what is the proper approach to the above problem in Maple (without any a priori knowledge, if possible)?
For instance, considering the expression  ≔ exp(1+LambertW(0,x))*(exp(1)*x+log[exp(1)](sqrt(2*Pi))-lnGAMMA(1/2+exp(1+LambertW(0,x))))
expr := exp(1+LambertW(x))*(exp(1)*x+ln(sqrt(2*Pi))-lnGAMMA(1/2+exp(1+LambertW(x)))) assuming x >= -1/exp(1):
The following limit can be calculated directly:
1/:-limit(expr, x = +infinity, 'left');
                               24
We can also evaluate ,
:-limit(1/expr, x = +infinity, 'left'); # MultiSeries:-limit also returns wrong result.
However, according to plot([1/(exp(1+LambertW(x))*(exp(1)*x+ln(sqrt(2*Pi))-lnGAMMA(1/2+exp(1+LambertW(x))))), 24], x = -1/exp(1) .. +exp(Pi), 'legend' = [1/expr, 24]), the limit value 0 cannot be correct.
So is this a bug? (And has this been fixed in the forthcoming version?)
SolnforOS_dsolve.mw
I would like to solve eq6 in terms of sigma and n. I would appreciate for your help.
I always trobled in coupled nonlinear equations.Could you please help to plot this.
PGVTN.mw
I what compute integral numerically with Precision 14 Digits. I try with:
evalf[2](Int(abs(sin(x^4))/(sqrt(x) + x^2), x = 0 .. infinity, method = _d01amc, methodoptions = [maxintervals = 50000]));# Works with 2 digits only.
I tried all the options and I failed to calculate with more precision.
with change variable: x = -ln(t) I got:
evalf[2](Int((ln(t)^2 - sqrt(-ln(t)))*abs(sin(ln(t)^4))/(ln(t)*(ln(t)^3 + 1)*t), t = 0 .. 1, method = _d01akc, methodoptions = [maxintervals = 500]));#Gives an error!!!
First 130 131 132 133 134 135 136 Last Page 132 of 2428
