Maple does not give solution to this first order ode with IC, if asked to do it implicit. It only solves it explicit.
ode := diff(y(x), x) - 2*(2*y(x) - x)/(x + y(x)) = 0;
ic:=y(0)=2;
dsolve([ode,ic],'implicit'); #maple gives no solution when implicit!
Then I asked Maple for an implicit solution but with no IC. Then solved for the constant of integration myself, and plugged this back in the solution. But odetest now says the initial conditions do not verify.
Here are the steps I did to solve for the constant of integration. I do not see any error I made. Does any one see where my error is and why odetest does not verify the solution for IC?
This first order ode has unique solution. Here is my worksheet.
35220
ic:=y(0)=2;
diff(y(x), x)-2*(2*y(x)-x)/(x+y(x)) = 0
y(0) = 2
#lets now try finding the constant of integration ourself
sol:=dsolve(ode,'implicit')
2*ln(-(-y(x)+x)/x)-3*ln(-(-y(x)+2*x)/x)-ln(x)-c__1 = 0
#setup equation and plugin the IC. Raise both sides to exp. RHS becomes 1
eq:=exp(lhs(sol))=1;
exp(2*ln(-(-y(x)+x)/x)-3*ln(-(-y(x)+2*x)/x)-ln(x)-c__1) = 1
simplify(eq,exp);
(y(x)-x)^2*exp(-c__1)/(y(x)-2*x)^3 = 1
#plugin in y=2 at x=0
eval(%,[y(x)=2,x=0]);
(1/2)*exp(-c__1) = 1
#solve for constant of integration
solve(%,c__1)
-ln(2)
#subtitute back in the solution
sol:=eval(sol,c__1=%);
2*ln(-(-y(x)+x)/x)-3*ln(-(-y(x)+2*x)/x)-ln(x)+ln(2) = 0
#verify. Why it failed check on IC?? Notice it is not [0,0].
odetest(sol,[ode,ic])
[0, 2]
Download why_fails_to_verify.mw
I bought Maple 2023 student version. (I am student) and installed it on windows 10.
I wanted to try it on Linux to see if runs better. So Installed the Linux version. When I tried to activate using the same purchase code I got, I get error that I have no more activations or I exceeded the number of activations.
But I installed Maple 2023 only one time, on windows which is my main OS. Never installed it anywhere else before.
Is one really only allowed one installation?
How would then I can try Maple on Linux but keep my Maple on windows until I decide if Maple works better on Linux or not?
Please, I need your help. I want to plot the spectrum of a dataset in #Problem 1.
In #Problem 2 If it is possible, how can I convert that function from the time domain to the frequency domain?
Fourier_transform.mw
I would like to apply the pappus theorem to an ellipse. Pascale's theorem
How to insert a condition in the final graph to display the parabola, its vertex, the axis of symmetry, and the roots (if they exist), and only display the parabola, the vertex, and its axis of symmetry otherwise. Thank you for your insights
S5AléatoireParaboleSommetGraphe.mw
Greetings! I need a maple code of logarithm of residuals for graphical comparison of iterative methods. Can anyone help me out by sharing a code comparing log of residuals of 2 or 3 iterative methods?
I think the GF function, input, accepts out-of-range inputs.
From ?GF: The G:-input and G:-output commands convert from an integer in the range
  "0 .. p^k - 1" to the corresponding polynomial and back
GF_strange.mw
The first GF was from a typo. I think it should have produced an error message, according to help.
If I understand correctly, GF(7,1) should only have 7 members.
The second GF is to allow the input 28856.
Tom Dean
This first order ode is quadrature with initial conditions. By existence theorem it has solution and is unique on some interval that includes the initial conditions (because f and f_y  are continuous on the initial condition).
But for some reason Maple can't find the solution, unless one adds 'implicit' option. Why is that? I thought that Maple will automatically return implicit solution if can't find explicit solution.
So does one then needs to try with implicit solution again if no solution is returned? I am basically asking if this is expected behavior of dsolve.
Below is worksheet also with the solution that Maple verifies is valid and satisfies the ode and also initial conditions.
ode:=diff(y(x), x) = sin(y(x)) + 1;
ic:=y(0)=Pi;
sol:=dsolve([ode,ic]);
20212
`The "Physics Updates" version in the MapleCloud is 1618 and is the same as the version installed in this computer, created 2023, November 29, 17:28 hours Pacific Time.`
ic:=y(0)=Pi;
diff(y(x), x) = sin(y(x))+1
y(0) = Pi
maple_sol:=dsolve([ode,ic],'implicit');
odetest(maple_sol,[ode,ic])
(2+x*tan((1/2)*y(x))+x)/(tan((1/2)*y(x))+1) = 0
[0, 0]
maple_sol:=dsolve([ode,ic],y(x),'explicit');
mysol:=y(x)=2*arccos(-x/(sqrt(4+4*x+2*x^2)));
odetest(mysol,[ode,ic]) assuming x>=0
y(x) = 2*Pi-2*arccos(x/(2*x^2+4*x+4)^(1/2))
[0, 0]
Download unable_to_dsolve_quadature_dec_22_2023.mw
Why does
eq:=Z^2=y/x;
solve(eq,Z)
give
I never told maple that y>=0 and x>=0 ?   I was expecting what we will do by hand. which is
Note that sqrt(x*y) is same as sqrt(x)*sqrt(y) only when y and x are not negative.
Is there an option to make Maple not do this and give same result as above? I tried PDEtools:-Solve and it gives same solution as solve.
Maple 2023.2.1 on windows 10
Notional example:
I use mtaylor compute the Taylor expansion of a function f (U) of several variables U1, .., UN.
In the resul the terms are ordered this way:
  • the leftmost term is f (P) where P denotes the point where the expansion is done
  • followed by a succession of terms :
    • firstly ranked according to the total order of derivation of  f.
    • and among terms of same derivation order, ranked in some kind of lexicographic order
For instance
Vars    := [seq(U[i], i=1..2)]:
AtPoint := [seq(P[i], i=1..2)]:
mt      := mtaylor(f(Vars[]), Vars =~ AtPoint, 3)
f(P[1], P[2])+(D[1](f))(P[1], P[2])*(U[1]-P[1])+(D[2](f))(P[1], P[2])*(U[2]-P[2])+(1/2)*(D[1, 1](f))(P[1], P[2])*(U[1]-P[1])^2+(D[1, 2](f))(P[1], P[2])*(U[1]-P[1])*(U[2]-P[2])+(1/2)*(D[2, 2](f))(P[1], P[2])*(U[2]-P[2])^2
map(t -> op([0, 0], select(has, [op(t)], D)[]), [op(mt)][2..-1])
[D[1], D[2], D[1, 1], D[1, 2], D[2, 2]]
Download mtaylor.mw
How could I define another ordering of the terms in this mtaylor expansion?
For instance 1 being identified to some letter and 2 to another one such that 1 <  2 a lexicographic order would be
D[1], D[1, 1], D[1, 2], D[2], D[2, 2]
I'm trying to symbolically diagonalize a 5x5 matrix in Maple. I can determine the eigenvalues for my matrix, but when it comes to evaluating the eigenvectors, Maple gives me the following results:
eigenvalues(A): -a + u, a + u, u, u, u
eigenvectors(A): [a + u, 1, {r}], [-a + u, 1, {r}], [u, 5, {r, r, r, r, r}]
I don't understand why I'm getting {r} in the eigenvectors. How can I display the eigenvectors for my matrix A?
Thank you in advance for your answers !
5x5
restartNULL
with(linalg)
[BlockDiagonal, GramSchmidt, JordanBlock, LUdecomp, QRdecomp, Wronskian, addcol, addrow, adj, adjoint, angle, augment, backsub, band, basis, bezout, blockmatrix, charmat, charpoly, cholesky, col, coldim, colspace, colspan, companion, concat, cond, copyinto, crossprod, curl, definite, delcols, delrows, det, diag, diverge, dotprod, eigenvals, eigenvalues, eigenvectors, eigenvects, entermatrix, equal, exponential, extend, ffgausselim, fibonacci, forwardsub, frobenius, gausselim, gaussjord, geneqns, genmatrix, grad, hadamard, hermite, hessian, hilbert, htranspose, ihermite, indexfunc, innerprod, intbasis, inverse, ismith, issimilar, iszero, jacobian, jordan, kernel, laplacian, leastsqrs, linsolve, matadd, matrix, minor, minpoly, mulcol, mulrow, multiply, norm, normalize, nullspace, orthog, permanent, pivot, potential, randmatrix, randvector, rank, ratform, row, rowdim, rowspace, rowspan, rref, scalarmul, singularvals, smith, stackmatrix, submatrix, subvector, sumbasis, swapcol, swaprow, sylvester, toeplitz, trace, transpose, vandermonde, vecpotent, vectdim, vector, wronskian]
(1.1)
A := Matrix([[0, 1, 0, 0, 0], [(gamma-1)*H-u^2-a^2, (3-gamma)*u, -(gamma-1)*v, -(gamma-1)*w, gamma-1], [-u*v, v, u, 0, 0], [-u*w, w, 0, u, 0], [u*((gamma-2)*H-a^2), H-(gamma-1)*u^2, -(gamma-1)*u*v, -(gamma-1)*u*w, gamma*u]])
Matrix(%id = 18446746202416421574)
(1.2)
eigenvalues(A)
u+(-gamma*u^2-gamma*v^2-gamma*w^2+2*H*gamma-a^2+u^2+v^2+w^2-2*H)^(1/2), u-(-gamma*u^2-gamma*v^2-gamma*w^2+2*H*gamma-a^2+u^2+v^2+w^2-2*H)^(1/2), u, u, u
(1.3)
V := sqrt(u^2+v^2+w^2)
(u^2+v^2+w^2)^(1/2)
(1.4)
H := (1/2)*V^2+a^2/(gamma-1)
(1/2)*u^2+(1/2)*v^2+(1/2)*w^2+a^2/(gamma-1)
(1.5)
eigenvalues(A)
-a+u, a+u, u, u, u
(1.6)
eigenvectors(A)
[-a+u, 1, {r}], [a+u, 1, {r}], [u, 3, {r, r, r}]
(1.7)
Download maps.mw
with(LinearAlgebra)
prel := {p1 = (1/2)*exp(I*a*x*(1/2)+I*b*t*(1/2))*(I*a*g[1](t, x)+2*(diff(g[1](t, x), x))), p2 = -(1/2)*exp(-I*a*x*(1/2)-I*b*t*(1/2))*(I*a*g[2](t, x)-2*(diff(g[2](t, x), x))), p3 = -(1/2)*exp(-I*a*x*(1/2)-I*b*t*(1/2))*(I*a*g[3](t, x)-2*(diff(g[3](t, x), x)))}
{p1 = (1/2)*exp(((1/2)*I)*a*x+((1/2)*I)*b*t)*(I*a*g[1](t, x)+2*(diff(g[1](t, x), x))), p2 = -(1/2)*exp(-((1/2)*I)*a*x-((1/2)*I)*b*t)*(I*a*g[2](t, x)-2*(diff(g[2](t, x), x))), p3 = -(1/2)*exp(-((1/2)*I)*a*x-((1/2)*I)*b*t)*(I*a*g[3](t, x)-2*(diff(g[3](t, x), x)))}
A := Matrix([[rhs(prel[1]), rhs(prel[2]), rhs(prel[3])]])
A1 := Transpose(A)
Matrix(%id = 36893490201564614396)
prel1 := {p4 = exp((1/2*I)*a*x+(1/2*I)*b*t)*(-I*lambda*g[1](t, x)+c[1]*g[2](t, x)+c[2]*g[3](t, x)), p5 = exp(-(1/2*I)*a*x-(1/2*I)*b*t)*(I*lambda*g[2](t, x)-c[1]*g[1](t, x)), p6 = exp(-(1/2*I)*a*x-(1/2*I)*b*t)*(I*lambda*g[3](t, x)-c[2]*g[1](t, x))}
{p4 = exp(((1/2)*I)*a*x+((1/2)*I)*b*t)*(-I*lambda*g[1](t, x)+c[1]*g[2](t, x)+c[2]*g[3](t, x)), p5 = exp(-((1/2)*I)*a*x-((1/2)*I)*b*t)*(I*lambda*g[2](t, x)-c[1]*g[1](t, x)), p6 = exp(-((1/2)*I)*a*x-((1/2)*I)*b*t)*(I*lambda*g[3](t, x)-c[2]*g[1](t, x))}
A2 := Matrix([[rhs(prel1[1]), rhs(prel1[2]), rhs(prel1[3])]]); A3 := Transpose(A2)
Matrix(%id = 36893490201519962460)
Download simplify2getgXisBg.mw
This worksheet loses contact with the kernel. I asked Tech Support. How do I report a bug?
Hung.mw
The last line was a typo, but, it should not lose contact with the kernel...
After executing the print statement,
> 1
produces the error message.
Tom Dean
For example, here are two equations containing trigonometric functions (Note that they do not form one system!):
restart; # There are more examples, yet for the sake of briefness, they are omitted here.
eqn__0 := cos(x)*cos(y)*cos(x + y) = 2*(sin(x)*sin(y) - 1)*2*(sin(x)*sin(x + y) - 1)*2*(sin(y)*sin(x + y) - 1):
eqn__1 := (cos(x + y) - (cos(x) + cos(y)) + 1)**2 + 2*cos(x)*cos(y)*cos(x + y) = 0:
Unfortunately, none of
(* Tag0 *) RealDomain:-solve(eqn__0, {y, x}):
(* Tag1 *) solve(eqn__0, {y, x}) assuming y + x >= 0, (y, x) <=~ Pi:
(* Tag2 *) RealDomain:-solve(eqn__1, {y, x}):
(* Tag3 *) solve(eqn__1, {y, x}) assuming y + x >= 0, (y, x) <=~ Pi:
outputs concise solutions.
Using `plot3d`, it is easy to check that when "And(y + x >= 0, (y, x) <=~ Pi)", “{y = Pi/2, x = 0}, {y = Pi/3, x = Pi/3}, {y = 0, x = Pi/2}, {y = Pi/2, x = Pi/2}” is both the only solution to "eqn__0" and the only solution to "eqn__1". But how to get Maple to do so without manual intervention?
Edit. The main purpose is to automatically find the generic solutions to each of the two equations (Tag0 and Tag2) (separately). Now that the cosine and sine functions are both periodic with period 2π and both (lhs - rhs)(eqn__0) and (lhs - rhs)(eqn__1) are even symmetric, it is enough to focus only on the region y + x ≥ 0 ∧ (y, x) ≤~ Pi. So, in theory, a second-best workaround should be Tag1 and Tag3. However, why is Maple still unable to find the four exact solutions above?
This could be new bug in 2023.2.1, could someone else confirm if it is in earlier versions 2023.2 ?
ode:=diff(y(x),x)-y(x)^2-m*y(x)*cot(x)-b^2*sin(x)^(2*m) = 0;
DEtools:-symgen(ode)
Error, (in trig/reduce) too many levels of recursion
After about 30 seconds.
I tried it in Maple 2022.2  I waited for more than 10 minutes and it was still running.  If you think it is new bug, will send email to Maple support.
The big problem with these Maple internal errors, is that it is not possible to trap them with try/catch. So the program simply crashes and there is no workaround.
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1615 and is the same as the version installed in this computer, created 2023, November 29, 17:28 hours Pacific Time.`
diff(y(x), x)-y(x)^2-m*y(x)*cot(x)-b^2*sin(x)^(2*m) = 0
DEtools:-symgen(ode);
Error, (in tools/map) too many levels of recursion
reported to Maple support
Download trig_reduce_recursion_dec_20_2023.mw
First 143 144 145 146 147 148 149 Last Page 145 of 2428
