sachi_stream_error_3d.mw  3d_sachin_p1.mw
Dear sir, there is something missing why it is not able to evaluate?
By reference of some posts I have implemented to my ODE but not getting the graph.
what is the mistake in both files?
At the moment I am focused on learning the Math (Calculus, then Differential Equations) and have been using Maple primarily to check the answers I got on a textbook problem.
I learn best by example but I realize that not knowing how to read the help pages really is a disadvantage.  I would like to learn how to use this amazing application more effectively in the future.  Can anyone give me tips on learning Maple with the help pages?  I got a primer on Maple but that hasn't been enough because I haven't used Maple enough.  How did you learn Maple and how do you think one can do this more quickly?
Thank You in advance.
 I have been trying to run a code to plot a region of stability for a numerical method for solving IVPs. Apart from the fact that it is taking time to run, it is giving me errors: 'Error; (inplots/ implicitplot/factor) and  Error; (inplot/ iplot2d:-Levels ) could not evaluate expression'
 Attached here is the code:
K=4
P1 := simplify(A1-ScalarMultiply(A3, z)-ScalarMultiply(A5, z^3)):
Error, (in plots/implicitplot/factor) invalid input: the following extra unknowns were found in the input expression: {P5[4]}
Error, (in plot/iplot2d:-Levels) could not evaluate expression
Download RAS(TDFFAM).mw
I am trying to learn how to use SurfaceInt in the VectorCalculus package to check my work on the even numbered problems in my Calculus book.
I can't seem to figure out how to define any surface in general.
One example in the help page is
SurfaceInt(1, [x, y, z] = Surface(<r, s, t>, s = 0 .. Pi, t = 0 .. 2*Pi, coords = spherical)) assuming (0 < r)
I can decode this one but can someone tell me what the word Surface is supposed to be? I think the surface is defined parametrically.  I can't find this command(?) or option(?) in the help pages. I am not even sure what part of the syntax it would be.
I don't want to ask for a lesson from anyone (time is so precious and valuable).  I just need a pointer to learn how to use "Surface."  Where is it defined?  What concepts in maple do I need to decode and also construct a Surface for the SurfaceInt command?  Do I just need to learn how to do paramterizations in Maple?
I have this image on a vase and I want to flatten it using Maple to see how it would look on a flat piece of paper.  How can we go about it.
The image is attached.
Image1-Greek.zip
Please help me check why my minmax optimization is not having these errors:
Error, (in minimize/cell/function/multidependence/univariate)
Error, n should be an integer for integer[n]
Error, (in minimize/cell/function/multidependence/univariate) invalid input: `minimize/continuous` expects its 2nd argument, yFP, to be of type {name, list(name)}, but received `X[4,3]` = -infinity
Error, invalid input: `convert/Array` expects its 1st argument, A, to be of type {Array, Matrix, Vector, array, sequential}, but received 0
my design optimization objective function is to carry out a minimize the maximum assignments from vector B overlap  between any two members in A , such that in vector A all members fall under a group and there is no duplication of membership, further   a member from each group representing the group  is to be assigned to vector B such that only one member of a group should be assigned each member of vector B, while ensuring that every member in vector B has represntation from every group in vector A.
with(Optimization); num_profiles := 4; num_websites := 3; num_groups := 2; X := Array(1 .. num_profiles, 1 .. num_websites, datatype = integer[0 .. 1]); obj := minimize(max(seq(add(X[i, j], j = 1 .. num_websites), i = 1 .. num_profiles))); constraints := {seq(add(add(X[i, j], i = k*num_profiles/num_groups+1 .. (k+1)*num_profiles/num_groups), k = 0 .. num_groups-1) = 1, j = 1 .. num_websites)}; sol := Optimization[Minimize](obj, constraints, assume = binary); optimal_assignment := convert(sol[1], Array); for i to num_profiles do for j to num_websites do if optimal_assignment[i, j] = 1 then print("Profile ", i, " assigned to Website ", j) end if end do end do; print("Objective Value (Minimized Maximum Website Overlap): ", sol[2])
"Objective Value (Minimized Maximum Website Overlap): ", [obj = 0, X[1, 1] = 0, X[1, 2] = 0, X[1, 3] = 0, X[2, 1] = 0, X[2, 2] = 0, X[2, 3] = 1, X[3, 1] = 1, X[3, 2] = 1, X[3, 3] = 0, X[4, 1] = 0, X[4, 2] = 0, X[4, 3] = 0]
Download firstworkablecode.mw
Hi. I need some help.... Where can i find my purchase Code to activate? Without it i can not work now..
I am trying to decompose an isprime into sum of 2 squares.
Can you tell me why yhse procedure are not goog.
Sumof2Squares:= proc(p::And(prime, satisfies(p-> irem(p,4)=1)))
local x, y:= 1;
   x:= mods(Roots(x^2+y^2), p)[2,1];
   while x^2+y^2 > p do
      (x,y):= FermatDescent(x,y,p)
   (x,y)
FermatDescent:= proc(x::posint, y::posint, p::posint)
local
   m:= (x^2+y^2)/p,
   a:= mods(x,m),
   b:= mods(y,m);
   (abs((a*x+b*y)/m), abs((a*y-b*x)/m))
trace(FermatDescent);
Sumof2Squares(1973);
My equation is
at  x=0
I got g'(0) in my previous equation,
And all the parameters are mensioned in the worksheet.Then how to plot eta.Help me.
FE-2.mw
with(Maplets[Examples]):
with(Student[Calculus1]):
Digits:=100:
``lambda[C] := .5
.5
lambda[L] := .5
.5
beta := 0.1e-1
0.1e-1
alpha := .5
.5
X[0]:=0;X[1]:=0.5;X[2]:=1;
 #A: Governing Equations:
 EQ[1] := lambda[C]^2*(diff(v[1](x), x, x, x, x, x, x))-(diff(v[1](x), x, x, x, x))
.25*(diff(diff(diff(diff(diff(diff(v[1](x), x), x), x), x), x), x))-(diff(diff(diff(diff(v[1](x), x), x), x), x))
EQ[2] := lambda[C]^2*(diff(v[2](x), x, x, x, x, x, x))-(diff(v[2](x), x, x, x, x))
.25*(diff(diff(diff(diff(diff(diff(v[2](x), x), x), x), x), x), x))-(diff(diff(diff(diff(v[2](x), x), x), x), x))
EQ[3] := s[1](x)+diff(v[1](x), x)-lambda[C]^2*(diff(s[1](x), x, x)+diff(v[1](x), x, x, x))-beta*(diff(v[1](x), x, x, x)-lambda[C]^2*(diff(v[1](x), x, x, x, x, x)))
s[1](x)+diff(v[1](x), x)-.25*(diff(diff(s[1](x), x), x))-.26*(diff(diff(diff(v[1](x), x), x), x))+0.25e-2*(diff(diff(diff(diff(diff(v[1](x), x), x), x), x), x))
EQ[4] := s[2](x)+diff(v[2](x), x)-lambda[C]^2*(diff(s[2](x), x, x)+diff(v[2](x), x, x, x))-beta*(diff(v[2](x), x, x, x)-lambda[C]^2*(diff(v[2](x), x, x, x, x, x)))
s[2](x)+diff(v[2](x), x)-.25*(diff(diff(s[2](x), x), x))-.26*(diff(diff(diff(v[2](x), x), x), x))+0.25e-2*(diff(diff(diff(diff(diff(v[2](x), x), x), x), x), x))
assign(dsolve({EQ[1], EQ[2], EQ[3], EQ[4]}, {s[1](x), s[2](x), v[1](x), v[2](x)}))
V[1] := subs(_C1 = A[1], _C2 = A[2], _C3 = A[3], _C4 = A[4], _C5 = A[5], _C6 = A[6], _C7 = A[7], _C8 = A[8], _C9 = A[9], _C10 = A[10], _C11 = A[11], _C12 = A[12], _C13 = A[13], _C14 = A[14], _C15 = A[15], _C16 = A[16], v[1](x))
V[2] := subs(_C1 = A[1], _C2 = A[2], _C3 = A[3], _C4 = A[4], _C5 = A[5], _C6 = A[6], _C7 = A[7], _C8 = A[8], _C9 = A[9], _C10 = A[10], _C11 = A[11], _C12 = A[12], _C13 = A[13], _C14 = A[14], _C15 = A[15], _C16 = A[16], v[2](x))
S[1] := subs(_C1 = A[1], _C2 = A[2], _C3 = A[3], _C4 = A[4], _C5 = A[5], _C6 = A[6], _C7 = A[7], _C8 = A[8], _C9 = A[9], _C10 = A[10], _C11 = A[11], _C12 = A[12], _C13 = A[13], _C14 = A[14], _C15 = A[15], _C16 = A[16], s[1](x))
NULL``
S[2] := subs(_C1 = A[1], _C2 = A[2], _C3 = A[3], _C4 = A[4], _C5 = A[5], _C6 = A[6], _C7 = A[7], _C8 = A[8], _C9 = A[9], _C10 = A[10], _C11 = A[11], _C12 = A[12], _C13 = A[13], _C14 = A[14], _C15 = A[15], _C16 = A[16], s[2](x))
# B: Costitutive Boundary Conditions:
eq[1] := evalf(eval((alpha*lambda[C]^4+lambda[C]^2*lambda[L]^2)*(diff(V[1], x, x, x, x, x))-alpha*lambda[C]^3*(diff(V[1], x, x, x, x))+(-alpha*lambda[C]^2+lambda[C]^2-lambda[L]^2)*(diff(V[1], x, x, x))+(alpha*lambda[C]-lambda[C])*(diff(V[1], x, x)), x = X[0]))
-4.00000*A[16]-.750*A[14]-.50*A[13]
eq[2] := evalf(eval((alpha*lambda[C]^4+lambda[C]^2*lambda[L]^2)*(diff(V[2], x, x, x, x, x))+alpha*lambda[C]^3*(diff(V[2], x, x, x, x))+(-alpha*lambda[C]^2+lambda[C]^2-lambda[L]^2)*(diff(V[2], x, x, x))+(-alpha*lambda[C]+lambda[C])*(diff(V[2], x, x)), x = X[2]))
10.87312731383618094144114988541064999102898837479983829986787051089630652141419037828552871410066571*A[9]+.50*A[7]
eq[3] := evalf(eval(lambda[C]^2*(diff(S[1], x)+diff(V[1], x, x))-lambda[C]*(S[1]+diff(V[1], x))+alpha*beta*lambda[C]*(diff(V[1], x, x, x)-lambda[C]^2*(diff(V[1], x, x, x, x, x))), x = X[0]))
-1.00*A[3]+0.8000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-1*A[16]-0.1500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-1*A[14]
eq[4] := evalf(eval(lambda[C]^2*(diff(S[2], x)+diff(V[2], x, x))+lambda[C]*(S[2]+diff(V[2], x))-alpha*beta*lambda[C]*(diff(V[2], x, x, x)-lambda[C]^2*(diff(V[2], x, x, x, x, x))), x = X[2]))
7.389056098930650227230427460575007813180315570551847324087127822522573796079057763384312485079121795*A[2]+.5911244879144520181784341968460006250544252456441477859269702258018059036863246210707449988063297436*A[9]+0.1500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000e-1*A[8]
NULLNULL
eq[5] := evalf(eval(alpha*lambda[C]^4*(diff(V[1], x, x, x, x, x))-alpha*lambda[C]^3*(diff(V[1], x, x, x, x))+(-alpha*lambda[C]^2+lambda[C]^2)*(diff(V[1], x, x, x))+(alpha*lambda[C]-lambda[C])*(diff(V[1], x, x))+(1-alpha)*(int(exp((z-x)/lambda[C])*(diff(V[1], x, x)-lambda[C]^2*(diff(V[1], x, x, x, x))), z = X[0] .. X[1]))-lambda[L]^2*(diff(int(exp((z-x)/lambda[C])*(diff(V[1], x, x, x)-lambda[C]^2*(diff(V[1], x, x, x, x, x))), z = X[0] .. x), x)), x = X[1]))
-1.471517764685769286382095080645843469783244524127071338031347206789845982979599213428589097383678575*A[16]-0.777287426357452235899284828632869517530750448214776276426328038192883654260245575535813672783191983e-1*A[14]-.1839397205857211607977618850807304337229055655158839172539184008487307478724499016785736371729598218*A[13]
(14)
NULL``
eq[6] := evalf(eval(alpha*lambda[C]^4*(diff(V[2], x, x, x, x, x))+alpha*lambda[C]^3*(diff(V[2], x, x, x, x))+(-alpha*lambda[C]^2+lambda[C]^2)*(diff(V[2], x, x, x))+(-alpha*lambda[C]+lambda[C])*(diff(V[2], x, x))-(1-alpha)*(int(exp((x-z)/lambda[C])*(diff(V[2], x, x)-lambda[C]^2*(diff(V[2], x, x, x, x))), z = X[1] .. X[2]))+lambda[L]^2*(diff(int(exp((x-z)/lambda[C])*(diff(V[2], x, x, x)-lambda[C]^2*(diff(V[2], x, x, x, x, x))), z = x .. X[2]), x)), x = X[1]))
10.87312731383618094144114988541064999102898837479983829986787051089630652141419037828552871410066571*A[9]+.4740904191214182588033571723789043494156416517261741241191223987269038781913251474821395442405602671*A[8]+.1839397205857211607977618850807304337229055655158839172539184008487307478724499016785736371729598218*A[7]
(15)
eq[7] := evalf(eval(lambda[C]^2*(diff(S[1], x)+diff(V[1], x, x))-lambda[C]*(S[1]+diff(V[1], x))+alpha*beta*lambda[C]*(diff(V[1], x, x, x)-lambda[C]^2*(diff(V[1], x, x, x, x, x)))+(1-alpha)*beta*(int(exp((z-x)/lambda[C])*(diff(V[1], x, x, x)-lambda[C]^2*(diff(V[1], x, x, x, x, x))), z = X[0] .. X[1])), x = X[1]))
-.3678794411714423215955237701614608674458111310317678345078368016974614957448998033571472743459196437*A[3]+0.2943035529371538572764190161291686939566489048254142676062694413579691965959198426857178194767357150e-1*A[16]-0.5518191617571634823932856552421913011687166965476517517617552025461922436173497050357209115188794656e-2*A[14]
(16)
eq[8] := evalf(eval(lambda[C]^2*(diff(S[2], x)+diff(V[2], x, x))+lambda[C]*(S[2]+diff(V[2], x))-alpha*beta*lambda[C]*(diff(V[2], x, x, x)-lambda[C]^2*(diff(V[2], x, x, x, x, x)))-(1-alpha)*beta*(int(exp((x-z)/lambda[C])*(diff(V[2], x, x, x)-lambda[C]^2*(diff(V[2], x, x, x, x, x))), z = X[1] .. X[2])), x = X[1]))
2.718281828459045235360287471352662497757247093699959574966967627724076630353547594571382178525166427*A[2]+.2174625462767236188288229977082129998205797674959967659973574102179261304282838075657105742820133142*A[9]+0.551819161757163482393285655242191301168716696547651751761755202546192243617349705035720911518879466e-2*A[8]
(17)
# D: Variationally Consistent Conditions:
eq[9] := evalf(eval(V[1], x = X[0]))
A[11]+A[15]+A[16]
(18)
eq[10] := evalf(eval(V[2], x = X[2]))
A[5]+A[6]+A[7]+A[8]+7.389056098930650227230427460575007813180315570551847324087127822522573796079057763384312485079121795*A[9]+.1353352832366126918939994949724844034076315459095758814681588726540733741014876899370981224906570488*A[10]
(19)
eq[11] := evalf(eval(V[1]-V[2], x = X[1]))
A[11]+.5*A[12]+.25*A[13]+.125*A[14]+2.718281828459045235360287471352662497757247093699959574966967627724076630353547594571382178525166427*A[15]+.3678794411714423215955237701614608674458111310317678345078368016974614957448998033571472743459196437*A[16]-1.*A[5]-.5*A[6]-.25*A[7]-.125*A[8]-2.718281828459045235360287471352662497757247093699959574966967627724076630353547594571382178525166427*A[9]-.3678794411714423215955237701614608674458111310317678345078368016974614957448998033571472743459196437*A[10]
(20)
eq[12] := evalf(eval(S[1]-S[2], x = X[1]))
2.718281828459045235360287471352662497757247093699959574966967627724076630353547594571382178525166427*A[4]+.3678794411714423215955237701614608674458111310317678345078368016974614957448998033571472743459196437*A[3]-1.*A[12]-1.0*A[13]-.6900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*A[14]-5.219101110641366851891751944997111995693914419903922383936577845230227130278811381577053782768319540*A[15]+.7063285270491692574634056387100048654959573715809942422550466592591260718302076224457227667441657159*A[16]-2.718281828459045235360287471352662497757247093699959574966967627724076630353547594571382178525166427*A[2]-.3678794411714423215955237701614608674458111310317678345078368016974614957448998033571472743459196437*A[1]+A[6]+1.0*A[7]+.6900000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000*A[8]+5.219101110641366851891751944997111995693914419903922383936577845230227130278811381577053782768319540*A[9]-.7063285270491692574634056387100048654959573715809942422550466592591260718302076224457227667441657159*A[10]
(21)
eq[13] := evalf(eval(lambda[C]^2*(diff(V[1], x, x, x, x))-(diff(V[1], x, x)), x = X[0]))
-2.*A[13]
(22)
eq[14] := evalf(eval(lambda[C]^2*(diff(V[2], x, x, x, x))-(diff(V[2], x, x)), x = X[2]))
-2.*A[7]-6.*A[8]
(23)
NULL````
eq[15] := evalf(eval(diff(V[1], x, x)-(diff(V[2], x, x))-lambda[C]^2*(diff(V[1], x, x, x, x)-(diff(V[2], x, x, x, x))), x = X[1]))
-2.*A[7]-3.0*A[8]+2.*A[13]+3.0*A[14]
(24)
eq[16] := evalf(eval(diff(V[1], x, x, x)-(diff(V[2], x, x, x))-lambda[C]^2*(diff(V[1], x, x, x, x, x)-(diff(V[2], x, x, x, x, x)))-1, x = X[1]))
6.*A[14]-1.-6.*A[8]
(25)
equations := [seq(eq[i], i = 1 .. 16)]:
unknowns := [seq(A[i], i = 1 .. 16)]:
assign( solve(equations, unknowns)):
display(plot(V[1],x=X[0]..X[1]))
Warning, expecting only range variable x in expression A[11]+A[12]*x+A[13]*x^2+A[14]*x^3+A[15]*exp(2*x)+A[16]*exp(-2*x) to be plotted but found names [A[11], A[12], A[13], A[14], A[15], A[16]]
eval(V[1], x = .5)
(26)
Hi.
I have faced a problem in solving a system of differential equations with 16 boundary conditions with maple. Unfortunately, maple does not solve it and I could not find out what the problem is. I share the maple file here and I will be grateful for any
Download Timoshenko_Beam.mw
I should like to find the list of Friday 13 of a year
The help page mentions:
The package supports five q-hypergeometric terms. They are q-Pochhammer symbol, q-binomial coefficient, q-brackets, q-factorial, and q-Gamma, which correspond to the five functions , , , , and .
But what about the so-called q-hypergeometric function? Though there exist QDifferenceEquations:-IsQHypergeometricTerm and QDifferenceEquations:-QHypergeometricSolution in Maple, they do not seem to represent the function itself
For example, how to type the q-Gauss sum (cf. DLMF's §17.6(i)) or verify the last “simple series expression” given in Basic hypergeometric series - Wikipedia? In Mma, one may achieve these with something like
while
convert("QHypergeometricPFQ[{a, b}, {c}, q, c/(a b)]", 'FromMma', 'evaluate');
                              /                 c \
            QHypergeometricPFQ|[a, b], [c], q, ---|
                              \                a b/
So has the q-hypergeometric function been implemented in Maple?
What is the correct way, in code, to check if Maple result contains any one of its own global build in symbols such as _Z or _C or any such symbol it uses?
I need to bypass this result. Currently I check explicitly, but I am sure there is a better way. Here is an example
r:=discont(1/tan(x),x);
This returns
Currently I do
if has(r,_Z1)  or has(r,_Z2) or has(r,_Z3) then
etc...
same for _C1, _C2., etc...
But this method is not robust. The problem is that _Z1 is symbol. So I can't check for symbol type in the  result as result could possibly have one of my own symbols there depending on input.
Is there  better way to do this? I am only asking about output of discont here and not any other Maple function. I assume discont uses _Zn only but I am not sure. It could use different symbol?
Example: Exanding the left hand side below to the right hand side
Unit('kg'*'m'/'s'^2) = Unit('kg')*Unit('m')/Unit('s')^2;
Such functionality would be useful for manipulating rational functions whose coefficients have units that can otherwise only be simplified by substituting new dimensionless independent variables as dicussed here.
Is there statement that can be mapped over an expression that identifies all subsexpressions with units and expands them to a products of units?
Probably not possible but also desireable: A variant that expands derived physical quantities to a product of base units as for example Newton to base units: Unit('N') = Unit('kg')*Unit('m')/Unit('s')^2;
Edit: Example from the link above on Unit expressions with compound units
Example that cannot be simplified
H(s) = 60.*Unit('m'*'kg'/('s'^2*'A'))/(.70805*s^2*Unit('kg'^2*'m'^2/('s'^3*'A'^2))+144.*s*Unit('kg'^2*'m'^2/('s'^4*'A'^2))+0.3675e-4*s^3*Unit('kg'^2*'m'^2/('s'^2*'A'^2)))
H(s) = 60.*Units:-Unit(m*kg/(s^2*A))/(.70805*s^2*Units:-Unit(kg^2*m^2/(s^3*A^2))+144.*s*Units:-Unit(kg^2*m^2/(s^4*A^2))+0.3675e-4*s^3*Units:-Unit(kg^2*m^2/(s^2*A^2)))
simplify(%)
After expansion of Unit expression (here done by hand) simplifcationis possible with other Maple commands
H(s) = 60.*Unit('m')*Unit('kg')/((.70805*s^2*Unit('kg')^2*Unit('m')^2/(Unit('s')^3*Unit('A')^2)+144.*s*Unit('kg')^2*Unit('m')^2/(Unit('s')^4*Unit('A')^2)+0.3675e-4*s^3*Unit('kg')^2*Unit('m')^2/(Unit('s')^2*Unit('A')^2))*Unit('s')^2*Unit('A'))
H(s) = 60.*Units:-Unit(m)*Units:-Unit(kg)/((.70805*s^2*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^3*Units:-Unit(A)^2)+144.*s*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^4*Units:-Unit(A)^2)+0.3675e-4*s^3*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^2*Units:-Unit(A)^2))*Units:-Unit(s)^2*Units:-Unit(A))
factor(H(s) = 60.*Units:-Unit(m)*Units:-Unit(kg)/((.70805*s^2*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^3*Units:-Unit(A)^2)+144.*s*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^4*Units:-Unit(A)^2)+0.3675e-4*s^3*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^2*Units:-Unit(A)^2))*Units:-Unit(s)^2*Units:-Unit(A)))
H(s) = 1632653.061*Units:-Unit(s)^2*Units:-Unit(A)/(Units:-Unit(m)*Units:-Unit(kg)*s*(19266.66666*s*Units:-Unit(s)+3918367.346+.9999999999*s^2*Units:-Unit(s)^2))
normal(H(s) = 60.*Units:-Unit(m)*Units:-Unit(kg)/((.70805*s^2*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^3*Units:-Unit(A)^2)+144.*s*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^4*Units:-Unit(A)^2)+0.3675e-4*s^3*Units:-Unit(kg)^2*Units:-Unit(m)^2/(Units:-Unit(s)^2*Units:-Unit(A)^2))*Units:-Unit(s)^2*Units:-Unit(A)))
H(s) = 60.*Units:-Unit(s)^2*Units:-Unit(A)/(Units:-Unit(m)*Units:-Unit(kg)*s*(.70805*s*Units:-Unit(s)+144.+0.3675e-4*s^2*Units:-Unit(s)^2))
Normalization to a dimensionless equation expression (that still has units) by a scaling factor with units
Sc := Unit('s')^3*Unit('A')/(Unit('m')*Unit('kg'))
Units:-Unit(s)^3*Units:-Unit(A)/(Units:-Unit(m)*Units:-Unit(kg))
(H(s) = 60.*Units[Unit](s)^2*Units[Unit](A)/(Units[Unit](m)*Units[Unit](kg)*s*(.70805*s*Units[Unit](s)+144.+0.3675e-4*s^2*Units[Unit](s)^2)))*(1/Sc)
Units:-Unit(m)*Units:-Unit(kg)*H(s)/(Units:-Unit(s)^3*Units:-Unit(A)) = 60./(Units:-Unit(s)*s*(.70805*s*Units:-Unit(s)+144.+0.3675e-4*s^2*Units:-Unit(s)^2))
Rewriting the left hand side
(proc (x) options operator, arrow; x = convert(x, units, m/V) end proc)(Sc)
Units:-Unit(s)^3*Units:-Unit(A)/(Units:-Unit(m)*Units:-Unit(kg)) = Units:-Unit(m/V)
isolate(Units[Unit](s)^3*Units[Unit](A)/(Units[Unit](m)*Units[Unit](kg)) = Units[Unit](m/V), Unit('m'))
Units:-Unit(m) = Units:-Unit(s)^3*Units:-Unit(A)/(Units:-Unit(m/V)*Units:-Unit(kg))
subs(Units[Unit](m) = Units[Unit](s)^3*Units[Unit](A)/(Units[Unit](m/V)*Units[Unit](kg)), Units[Unit](m)*Units[Unit](kg)*H(s)/(Units[Unit](s)^3*Units[Unit](A)) = 60./(Units[Unit](s)*s*(.70805*s*Units[Unit](s)+144.+0.3675e-4*s^2*Units[Unit](s)^2)))
H(s)/Units:-Unit(m/V) = 60./(Units:-Unit(s)*s*(.70805*s*Units:-Unit(s)+144.+0.3675e-4*s^2*Units:-Unit(s)^2))
Magnitude plot
abs(H(s)/Units[Unit](m/V) = 60./(Units[Unit](s)*s*(.70805*s*Units[Unit](s)+144.+0.3675e-4*s^2*Units[Unit](s)^2)))
abs(H(s))/Units:-Unit(m/V) = 60./(Units:-Unit(s)*abs(s*(.70805*s*Units:-Unit(s)+144.+0.3675e-4*s^2*Units:-Unit(s)^2)))
H(s) = H(f), s = I*omega, omega = 2*Pi*f
subs(H(s) = H(f), s = I*omega, omega = 2*Pi*f, abs(H(s))/Units[Unit](m/V) = 60./(Units[Unit](s)*abs(s*(.70805*s*Units[Unit](s)+144.+0.3675e-4*s^2*Units[Unit](s)^2))))
abs(H(f))/Units:-Unit(m/V) = 60./(Units:-Unit(s)*abs((2*I)*Pi*f*((4.448809357*I)*f*Units:-Unit(s)+144.-0.14700e-3*Pi^2*f^2*Units:-Unit(s)^2)))
plot(rhs(abs(H(f))/Units[Unit](m/V) = 60./(Units[Unit](s)*abs((2*I)*Pi*f*((4.448809357*I)*f*Units[Unit](s)+144.-0.14700e-3*Pi^2*f^2*Units[Unit](s)^2)))), f = 0*Unit('Hz') .. 10*Unit('Hz'), labels = [f/Unit('Hz'), lhs(abs(H(f))/Units[Unit](m/V) = 60./(Units[Unit](s)*abs((2*I)*Pi*f*((4.448809357*I)*f*Units[Unit](s)+144.-0.14700e-3*Pi^2*f^2*Units[Unit](s)^2))))])
Download Expansion_of_Unit_command_and_simplification_to_m_per_V.mw
First 144 145 146 147 148 149 150 Last Page 146 of 2428
