I have a pretty ugly nested integral (in my opinion) that I am trying to compute. I thought that I simplified the problem to an easier siutation however during my attempted calculations I am recieving: "Error, (in evalf/int) cannot handle unevaluated name `L` in evalhf
I am unsure where this is coming from, I would assume something in procedure or my attempted use of unapply is incorrect. Any comments are welcome, including those that state I am doing this entirely incorrectly.
NestedError.mw
I need to highlight all terms that contain eta, my variable, for example (A0)+(A1)*1/eta+(A2)*1/eta^2+...(An)**1/eta^n and so on in my expression call from P. However, when I select eta through the collect command, maple is unable to carry out the command.
P := expand((cosh(k*eta) + alpha*m*sinh(k*eta)/eta)^3);
P := convert(P, exp);
P := expand(P);
P := collect(P, eta);
P := combine(P);
Once these have are in evidence I need to select the coefficients A0, A1, A2, etc. How to proceed if eta are in the denominator and maple does not work with this possibility? This it'was my tentative
B0 := subs(eta = 0, P);
B1 := coeff(P, eta)
B2 := coeff(P, eta^2)
I actually tested the possibility of  1/eta instead of  eta and it didn't work
I am an ophthalmologist and a novice in programing. I am having a problem obtaining the x-y coordinate equations for each of the fitted Splines.  I can send the raw data and MapleSoft work sheet for which I need the individual spline equations, in x-y coodinates not parametric format and also need to be able to plot the splines on the raw data. I will pay for the service. Can you please obtain the x-y Cartesian equations for each of the fitted Splines and give me a step-wise method for obtaining them?  I am unable to attach the raw data and the worksheet to this email.  Please send me your personal email so that I can send them.
Your assistance is most appreciated.
With my best,
Ron
Ronald A Schachar MD , PhD
7241 Encelia Drive
La Jolla, CA 92037
Cell: (858) 784-1705
Email: ron@2ras.com
Is it possible to solve the following equation with Maple:
Find the smallest positive integers such that
a/(b+c)+b/(a+c)+c/(a+b)=4
The solutions are enormous.
See
https://www.agftutoring.com/x-yz-y-xz-z-xy-4/
WHen using _self in object, help says
"As of Maple 2021, if the method has a formal parameter named _self, references
to its object's local or exported variables may be written without prefixing them.
That is, _self:-variable may be written as just variable. Maple will
add the self:- prefix internally when the method is simplified."
And the above is true for all static methods inside an object module, except for ModuleCopy which is also static.
It seems ModuleCopy is special. But why?  I am thinking it is because at time this is called, the object itself does not yet exist, but for all other methods, the object by then is fully constructed. But wanted to be sure.
Here is an example
person := module()
option object;
local  m_name::string;
local  m_age::integer;
export ModuleCopy :: static := proc(_self :: person
                                   , proto :: person, name::string, age::integer,$
         m_age := age;
         m_name := name;
export name::static:= proc(_self, $);
    RETURN(m_name); #no need to write _self:-m_name;
export age::static:= proc(_self, $);
    RETURN(m_age); #no need to write _self:-m_age;
export set_name::static:= proc(_self, name, $);
    m_name := name;   #no need to write _self:-m_name := name
    NULL;
export process::static:=proc(_self,$)
   print("name is ",m_name," age is ",m_age);
end module:
And now
o:=Object(person,"me",10);
Error, static procedure `ModuleCopy` refers to non-static local or export `m_age::integer` in surrounding scope
Changing ModuleCopy to
         _self:-m_age := age;
         _self:-m_name := name;
Now there is no error. But notice that in all other static methods, I can write  m_name directly without using _self:-m_name;
I looked at help page for ModuleCopy but see no mention of this.
Why ModuleCopy is different?
Maple 2023.2 on windows 10
Can you generate equation numbers for inline equations?
Hi every one
I need a command or simple procedure to convert an ODE into a linear polynomial.
For example, let us consider the ode in the attached file. I want to return the poly in this file. draft1.mw
Could you please help me?
Is it possible to transform relation (2) into relation (7) without using the hand-made relation (3) and the  Sum -> Int -> Sum trick?
f := Product(x[i]^a*(1-x[i])^b, i)
Lf := ln(f);
ln(Product(x[i]^a*(1-x[i])^b, i))
Sum(ln(x[i]^a*(1-x[i])^b), i)
expand(%) assuming x[i] > 0, x[i] < 1, a > 0, b > 0
Sum(a*ln(x[i])+b*ln(1-x[i]), i)
eval(%, Sum=Int)
Int(a*ln(x[i])+b*ln(1-x[i]), i)
IntegrationTools:-Expand(%);
a*(Int(ln(x[i]), i))+b*(Int(ln(1-x[i]), i))
Lf = eval(%, Int=Sum)
ln(Product(x[i]^a*(1-x[i])^b, i)) = a*(Sum(ln(x[i]), i))+b*(Sum(ln(1-x[i]), i))
Download From2to7.mw
TIA
%fig1
%s1=sbeta./sgamma; sg= with gamma; sb= with beta; c=etar./eta;
%sigma=a./b;ur=uhat;
r=0.4:0.000001:1;
b1=0.0;b2=0.0;s=10000;sb=0;s1=sb./s;j=0;EZ=1;zeta0=-1;beta=1;i=(-1).^(1./2);
alpha=0.628; sigma=0.4; ur=0;
k=10;c=0.0000001;
%k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u1 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i*alpha .^ 2);
%nu1 = -T1 .* alpha11 .* besselk(1, alpha11 .* r) .* (alpha11 .^ 2 + T2) .* c1 + T1 .* alpha12 .* besseli(1, alpha12 .* r) .* (alpha12 .^ 2 + T2) .* c2 - T1 .* alpha22 .* besselk(1, alpha22 .* r) .* (alpha22 .^ 2 + T2) .* c3 + T1 .* alpha21 .* besseli(1, alpha21 .* r) .* (alpha21 .^ 2 + T2) .* c4 + T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%tr1 = -besselk(1, alpha11 .* r) .* alpha11 .* (2 .* T1 .* c .* alpha11 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c1 + besseli(1, alpha12 .* r) .* alpha12 .* (2 .* T1 .* c .* alpha12 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c2 - besselk(1, alpha22 .* r) .* alpha22 .* (2 .* T1 .* c .* alpha22 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c3 + besseli(1, alpha21 .* r) .* alpha21 .* (2 .* T1 .* c .* alpha21 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c4 + EZ .* k .* (2 .* KK .* T1 .* c .* k .^ 2 + 2 .* KK .* T1 .* T2 .* c + 2 .* T1 .* c .* k1 + KK .* c + KK) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%m1 = T1 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* r) .* alpha11 .* r + s1 .* besselk(1, alpha11 .* r) + besselk(1, alpha11 .* r)) ./ r .* c1 - T1 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* r) .* alpha12 .* r + s1 .* besseli(1, alpha12 .* r) + besseli(1, alpha12 .* r)) ./ r .* c2 + T1 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* r) .* alpha22 .* r + s1 .* besselk(1, alpha22 .* r) + besselk(1, alpha22 .* r)) ./ r .* c3 - T1 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* r) .* alpha21 .* r + s1 .* besseli(1, alpha21 .* r) + besseli(1, alpha21 .* r)) ./ r .* c4 - T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* r) .* k .* r - B1 .* besselk(0, k .* r) .* k .* r + A1 .* besseli(1, k .* r) .* s1 - B1 .* besselk(1, k .* r) .* s1 + A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r)) ./ r;
k=40;c=0.0000001;
k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u2 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i.*alpha .^ 2);
%nu1 = -T1 .* alpha11 .* besselk(1, alpha11 .* r) .* (alpha11 .^ 2 + T2) .* c1 + T1 .* alpha12 .* besseli(1, alpha12 .* r) .* (alpha12 .^ 2 + T2) .* c2 - T1 .* alpha22 .* besselk(1, alpha22 .* r) .* (alpha22 .^ 2 + T2) .* c3 + T1 .* alpha21 .* besseli(1, alpha21 .* r) .* (alpha21 .^ 2 + T2) .* c4 + T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%tr1 = -besselk(1, alpha11 .* r) .* alpha11 .* (2 .* T1 .* c .* alpha11 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c1 + besseli(1, alpha12 .* r) .* alpha12 .* (2 .* T1 .* c .* alpha12 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c2 - besselk(1, alpha22 .* r) .* alpha22 .* (2 .* T1 .* c .* alpha22 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c3 + besseli(1, alpha21 .* r) .* alpha21 .* (2 .* T1 .* c .* alpha21 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c4 + EZ .* k .* (2 .* KK .* T1 .* c .* k .^ 2 + 2 .* KK .* T1 .* T2 .* c + 2 .* T1 .* c .* k1 + KK .* c + KK) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%m1 = T1 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* r) .* alpha11 .* r + s1 .* besselk(1, alpha11 .* r) + besselk(1, alpha11 .* r)) ./ r .* c1 - T1 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* r) .* alpha12 .* r + s1 .* besseli(1, alpha12 .* r) + besseli(1, alpha12 .* r)) ./ r .* c2 + T1 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* r) .* alpha22 .* r + s1 .* besselk(1, alpha22 .* r) + besselk(1, alpha22 .* r)) ./ r .* c3 - T1 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* r) .* alpha21 .* r + s1 .* besseli(1, alpha21 .* r) + besseli(1, alpha21 .* r)) ./ r .* c4 - T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* r) .* k .* r - B1 .* besselk(0, k .* r) .* k .* r + A1 .* besseli(1, k .* r) .* s1 - B1 .* besselk(1, k .* r) .* s1 + A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r)) ./ r;
k=70;c=.0000001;
k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u3 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i.*alpha .^ 2);
%nu1 = -T1 .* alpha11 .* besselk(1, alpha11 .* r) .* (alpha11 .^ 2 + T2) .* c1 + T1 .* alpha12 .* besseli(1, alpha12 .* r) .* (alpha12 .^ 2 + T2) .* c2 - T1 .* alpha22 .* besselk(1, alpha22 .* r) .* (alpha22 .^ 2 + T2) .* c3 + T1 .* alpha21 .* besseli(1, alpha21 .* r) .* (alpha21 .^ 2 + T2) .* c4 + T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%tr1 = -besselk(1, alpha11 .* r) .* alpha11 .* (2 .* T1 .* c .* alpha11 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c1 + besseli(1, alpha12 .* r) .* alpha12 .* (2 .* T1 .* c .* alpha12 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c2 - besselk(1, alpha22 .* r) .* alpha22 .* (2 .* T1 .* c .* alpha22 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c3 + besseli(1, alpha21 .* r) .* alpha21 .* (2 .* T1 .* c .* alpha21 .^ 2 + 2 .* T1 .* T2 .* c + c + 1) .* c4 + EZ .* k .* (2 .* KK .* T1 .* c .* k .^ 2 + 2 .* KK .* T1 .* T2 .* c + 2 .* T1 .* c .* k1 + KK .* c + KK) .* (A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r));
%m1 = T1 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* r) .* alpha11 .* r + s1 .* besselk(1, alpha11 .* r) + besselk(1, alpha11 .* r)) ./ r .* c1 - T1 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* r) .* alpha12 .* r + s1 .* besseli(1, alpha12 .* r) + besseli(1, alpha12 .* r)) ./ r .* c2 + T1 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* r) .* alpha22 .* r + s1 .* besselk(1, alpha22 .* r) + besselk(1, alpha22 .* r)) ./ r .* c3 - T1 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* r) .* alpha21 .* r + s1 .* besseli(1, alpha21 .* r) + besseli(1, alpha21 .* r)) ./ r .* c4 - T1 .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* r) .* k .* r - B1 .* besselk(0, k .* r) .* k .* r + A1 .* besseli(1, k .* r) .* s1 - B1 .* besselk(1, k .* r) .* s1 + A1 .* besseli(1, k .* r) - B1 .* besselk(1, k .* r)) ./ r;
k=100;c=.0000001;
k1=k.^2.*zeta0./(1+c);
T1=(1+c)./(2.*s.*(i.*alpha.^2.*j-4.*c));
T2=(4.*s.*c-i.*alpha.^2)./(1+c);
r11=(4.*s.*c+i.*alpha.^2.*(c-j.*s.*(1+c)))./(c.*(1+c));r22=alpha.^2.*s.*(4.*i.*c+alpha.^2.*j)./(c.*(1+c));
alpha11=((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);alpha12=-((1./2).*(r11+(r11.^2-4.*r22).^(1./2))).^(1./2);
alpha22=((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);alpha21=-((1./2).*(r11-(r11.^2-4.*r22).^(1./2))).^(1./2);
KK=-(k1.*(k.^2-s.*(4-i.*alpha.^2.*j.*c.^(-1))))./(k.^4-(r11).*k.^2+r22);
A1=(beta*besselk(0, k)-besselk(0, k.* sigma))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
B1=(besseli(0, k.* sigma)-beta.*besseli(0, k))./(besseli(0, k.* sigma).*besselk(0, k )-besselk(0, k.* sigma).*besseli(0, k));
c1 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))))) ./ (((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)));
c2 = (((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) - (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)));
c3 = (((T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ)) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) - (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) - ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)));
c4 = (((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) + T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (A1 .* besseli(0, k) .* b2 .* k - A1 .* besseli(1, k) .* b2 .* s1 + B1 .* besselk(0, k) .* b2 .* k + B1 .* besselk(1, k) .* b2 .* s1 - A1 .* besseli(1, k) .* b2 + B1 .* besselk(1, k) .* b2 + A1 .* besseli(1, k) - B1 .* besselk(1, k)) - T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)) .* EZ .* k .* (KK .* k .^ 2 + KK .* T2 + k1) .* (-A1 .* besseli(0, k .* sigma) .* b2 .* k .* sigma - B1 .* besselk(0, k .* sigma) .* b2 .* k .* sigma + A1 .* besseli(1, k .* sigma) .* b2 .* s1 - B1 .* besselk(1, k .* sigma) .* b2 .* s1 + A1 .* besseli(1, k .* sigma) .* b2 + A1 .* besseli(1, k .* sigma) .* sigma - B1 .* besselk(1, k .* sigma) .* b2 - B1 .* besselk(1, k .* sigma) .* sigma) ./ sigma) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-ur ./ i ./ alpha .^ 2 - (2 .* A1 .* KK .* besseli(1, k) .* T1 .* b1 .* c .* k .^ 3 - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* b1 .* c .* k .^ 3 + 2 .* A1 .* KK .* besseli(1, k) .* T1 .* T2 .* b1 .* c .* k - 2 .* B1 .* KK .* besselk(1, k) .* T1 .* T2 .* b1 .* c .* k + 2 .* A1 .* besseli(1, k) .* T1 .* b1 .* c .* k .* k1 - 2 .* B1 .* besselk(1, k) .* T1 .* b1 .* c .* k .* k1 + A1 .* KK .* besseli(1, k) .* b1 .* c .* k - B1 .* KK .* besselk(1, k) .* b1 .* c .* k + A1 .* KK .* besseli(1, k) .* b1 .* k - B1 .* KK .* besselk(1, k) .* b1 .* k + A1 .* KK .* besseli(0, k) + B1 .* KK .* besselk(0, k)) .* EZ) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-ur ./ i ./ alpha .^ 2 - (-2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .^ 3 - 2 .* A1 .* KK .* besseli(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k + 2 .* B1 .* KK .* besselk(1, k .* sigma) .* T1 .* T2 .* b1 .* c .* k - 2 .* A1 .* besseli(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 + 2 .* B1 .* besselk(1, k .* sigma) .* T1 .* b1 .* c .* k .* k1 - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* c .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* c .* k - A1 .* KK .* besseli(1, k .* sigma) .* b1 .* k + B1 .* KK .* besselk(1, k .* sigma) .* b1 .* k + A1 .* KK .* besseli(0, k .* sigma) + B1 .* KK .* besselk(0, k .* sigma)) .* EZ) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))))) ./ (((-T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)))) .* (2 .* besselk(1, alpha11 .* sigma) .* T1 .* alpha11 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha11 .* sigma) .* T1 .* T2 .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 .* c + besselk(1, alpha11 .* sigma) .* alpha11 .* b1 + besselk(0, alpha11 .* sigma)) + ((T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) - (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (-2 .* besseli(1, alpha12 .* sigma) .* T1 .* alpha12 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha12 .* sigma) .* T1 .* T2 .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 .* c - besseli(1, alpha12 .* sigma) .* alpha12 .* b1 + besseli(0, alpha12 .* sigma)) + ((T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) - T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha21 .* (alpha21 .^ 2 + T2) .* (besseli(0, alpha21) .* alpha21 .* b2 - besseli(1, alpha21) .* b2 .* s1 - besseli(1, alpha21) .* b2 + besseli(1, alpha21)) + T1 .^ 2 .* alpha21 .* (alpha21 .^ 2 + T2) .* (-besseli(0, alpha21 .* sigma) .* alpha21 .* b2 .* sigma + besseli(1, alpha21 .* sigma) .* b2 .* s1 + besseli(1, alpha21 .* sigma) .* b2 + besseli(1, alpha21 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) + (2 .* besseli(1, alpha21) .* T1 .* alpha21 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha21) .* T1 .* T2 .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 .* c + besseli(1, alpha21) .* alpha21 .* b1 + besseli(0, alpha21)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))) .* (2 .* besselk(1, alpha22 .* sigma) .* T1 .* alpha22 .^ 3 .* b1 .* c + 2 .* besselk(1, alpha22 .* sigma) .* T1 .* T2 .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 .* c + besselk(1, alpha22 .* sigma) .* alpha22 .* b1 + besselk(0, alpha22 .* sigma)) + (-2 .* besseli(1, alpha21 .* sigma) .* T1 .* alpha21 .^ 3 .* b1 .* c - 2 .* besseli(1, alpha21 .* sigma) .* T1 .* T2 .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 .* c - besseli(1, alpha21 .* sigma) .* alpha21 .* b1 + besseli(0, alpha21 .* sigma)) .* ((-T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) - T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12))) .* (-2 .* besselk(1, alpha11) .* T1 .* alpha11 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha11) .* T1 .* T2 .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 .* c - besselk(1, alpha11) .* alpha11 .* b1 + besselk(0, alpha11)) + (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22) .* alpha22 .* b2 + besselk(1, alpha22) .* b2 .* s1 + besselk(1, alpha22) .* b2 - besselk(1, alpha22)) + T1 .^ 2 .* alpha22 .* (alpha22 .^ 2 + T2) .* (besselk(0, alpha22 .* sigma) .* alpha22 .* b2 .* sigma + besselk(1, alpha22 .* sigma) .* b2 .* s1 + besselk(1, alpha22 .* sigma) .* b2 + besselk(1, alpha22 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11))) .* (2 .* besseli(1, alpha12) .* T1 .* alpha12 .^ 3 .* b1 .* c + 2 .* besseli(1, alpha12) .* T1 .* T2 .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 .* c + besseli(1, alpha12) .* alpha12 .* b1 + besseli(0, alpha12)) - (-2 .* besselk(1, alpha22) .* T1 .* alpha22 .^ 3 .* b1 .* c - 2 .* besselk(1, alpha22) .* T1 .* T2 .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 .* c - besselk(1, alpha22) .* alpha22 .* b1 + besselk(0, alpha22)) .* (-T1 .^ 2 .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11 .* sigma) .* alpha11 .* b2 .* sigma + besselk(1, alpha11 .* sigma) .* b2 .* s1 + besselk(1, alpha11 .* sigma) .* b2 + besselk(1, alpha11 .* sigma) .* sigma) ./ sigma .* alpha12 .* (alpha12 .^ 2 + T2) .* (besseli(0, alpha12) .* alpha12 .* b2 - besseli(1, alpha12) .* b2 .* s1 - besseli(1, alpha12) .* b2 + besseli(1, alpha12)) - T1 .^ 2 .* alpha12 .* (alpha12 .^ 2 + T2) .* (-besseli(0, alpha12 .* sigma) .* alpha12 .* b2 .* sigma + besseli(1, alpha12 .* sigma) .* b2 .* s1 + besseli(1, alpha12 .* sigma) .* b2 + besseli(1, alpha12 .* sigma) .* sigma) ./ sigma .* alpha11 .* (alpha11 .^ 2 + T2) .* (besselk(0, alpha11) .* alpha11 .* b2 + besselk(1, alpha11) .* b2 .* s1 + besselk(1, alpha11) .* b2 - besselk(1, alpha11)))));
u4 = c1 .* besselk(0, alpha11 .* r) + c2 .* besseli(0, alpha12 .* r) + c3 .* besselk(0, alpha22 .* r) + c4 .* besseli(0, alpha21 .* r) + KK .* EZ .* A1 .* besseli(0, k .* r) + KK .* EZ .* B1 .* besselk(0, k .* r) + ur ./ (i.*alpha .^ 2);
T = table2array(u1);
Folks,
What is the simplist Maple code needed to isolate a vector that has two components?  See below:
Vector[column](2, [25.00000000*pi*r/(r^2 + z^2), 25.00000000*pi*z/(r^2 + z^2)])
I want to get the magnitude of this vector which is simply the square root of the sum of the squares of the individual components as shown above.
How do I do that?
Chris
I need the sign of eigenvalue of the given marrix.
Note that it is not essay to compute the eigenvalues but we can use  ROUTH Hurwitz criterion that give the sign of eigenvalues without computing them
stability.mw
I wish to substitute only the base of the ifactor expression like the following
lst := [24300, 18907875, 151200, 147000]
map(ifactor, lst)
[``(2)^2*``(3)^5*``(5)^2, ``(3)^2*``(5)^3*``(7)^5, ``(2)^5*``(3)^3*``(5)^2*``(7), ``(2)^3*``(3)*``(5)^3*``(7)^2]
subs(2 = x, %)
[``(x)^x*``(3)^5*``(5)^x, ``(3)^x*``(5)^3*``(7)^5, ``(x)^5*``(3)^3*``(5)^x*``(7), ``(x)^3*``(3)*``(5)^3*``(7)^x]
I wish my results to be
[x^2*3^5*5^2, 3^2*5^3*7^5, 7*x^5*3^3*5^2, 3*x^3*5^3*7^2]
[6075*x^2, 18907875, 4725*x^5, 18375*x^3]
such that
subs(x = 2, %)
evalb(% = lst)
Download SubsExample.mw
If there a way to do that? I understand that there is a command ifactors which gives me more control, but the form of the result is rather inconvenient. I hope there is a more direct way to do the aforementioned operation.
How can I draw Steiner trees of hypercubes in graph theory?
With the following steps
S1: Open Help pressing F1
S2: enter `if in the search field
S3: click a topic in the result list
S4: search within the topic with find/replace (Crtl f) the term `if
I get plenty of results where I cannot find the search term in the help topic. Why is that?
Is help ignoring the left single quotes ` ?
I don't think so: I get usefull results for `` and `i, which in the later case also lists the topic "ifelse" that contains `if in the textbody.
So, why does advanced searching with the exact phrase "`if" not list the "ifelse" topic?
Realted question:
Why does the search term "(* " not list the relevant help topic help(comment)?
Somehow related in the context of getting more specific results:
https://www.mapleprimes.com/questions/234462-Searching-The-Help-System-Why-Are-There-No-Hits-For-Solve
Can anyone help me with the following technique?
solutions:
First 148 149 150 151 152 153 154 Last Page 150 of 2428
